Back-up Camera
Old Dec 2, 2018 | 01:08 PM
oldmercman's Avatar
Default Back-up Camera
Looking for info on a quality, wireless back-up Camera system. I care nothing about a forward camera option option ( I can see where I'm going and don't need to record it)
The mirror mounted screens have appeal.....but the wires hanging down is not desirable. So I guess a dash mount is my only option. Wireless would make for an easy install with only a wired connection from the camera to the passenger side back up light. I have also read that is it's recommended to swap out the 1156 back-up lamps to LED units. I hope someone on this forum has done this installation and have some recommendations.
Thanks
Old Dec 8, 2018 | 04:20 PM
hnikesch's Avatar
Default Re: Back-up Camera
I installed a mirror monitor to a wired backup camera, wires are tucked up under the headliner and A pillar plastic cover then under the carpet back to the light and camera. Nothing can be seen except the camera mounted to the license plate. This is the one I used from Amazon, everything is included and it mounts to the XF mirror mount with included adapter.
Amazon Amazon
Old Dec 8, 2018 | 04:36 PM
oldmercman's Avatar
Thanks......I told my bride what I wanted (for Xmas).......it should end being up a wireless unit , also from Amazon, but with a dash or windshield mount....same brand.
I didn't want to mess around with concealing wires .etc. The camera wires to the back up light looks easy. I'll re-post at a later date with hopefully good results.
Again, thanks for your reply........
Old Dec 8, 2018 | 05:17 PM
maggy55's Avatar
Check this link
https://www.crossfireforum.org/forum...tallation.html
Old Dec 9, 2018 | 08:07 PM
Mdcrossfire's Avatar
I opted for a Whistler one available at Walmart. It is wireless in the back so all you need to do is mount it to the license plate . It has rechargeable lithium batteries that recharge by sunlight shinning on two thin solar panels on each side of the rear plate . In the front the monitor plugs into the lighter socket and mounts to the dash with a suction cup just like a GP S. Because it is not wired to the backup lights you simply push a button on the monitor before backing up and it stays on for 30 seconds. Very nice and looks great.
Old Dec 10, 2018 | 09:45 AM
oldmercman's Avatar
Looks like a nice unit.....my XF is garaged and only sees sunlight during an occasional run.....none this time of year as it's up on blocks for the winter. So the battery would be most likely flat when needed.
I also prefer the auto reverse on function over pushing a button. The one thing I've determined is that the screen in the rear view mirror units are way to small and also that the mirrors that have a blue tint
are worthless at night. 4.3" screens seem to be about right.
Thanks for posting your experience.
Old Dec 10, 2018 | 09:48 AM
hnikesch's Avatar
The mirror monitor is close to my head so the size is not an issue
Old Dec 10, 2018 | 10:53 AM
I have the wired one like yours on my other cars. One good thing about the Cross fire is the hole under the plate(is it supposed to have a cover over that quarter sized hole....anybody know?) On my other cars I had to drill a hole under the plate to pass the wire through. My tablet keeps leaving a space between cross and fire that I can't stop it from doing that!
Old Dec 10, 2018 | 12:21 PM
You can add the word Crossfire to the dictionary in your tablet.
Old Feb 16, 2020 | 09:16 PM
BeekeeperRob's Avatar
did it fit between the sun visors without hitting them?
Old Feb 17, 2020 | 10:16 AM
g wheels's Avatar
Yeah mine has the same hole you describe. No plug or cover for it on mine either.
Hope you (or someone) can answer a question since you have had experience running the video / IR cable through that hole. I'm in the process of removing the inside panel(s) to get to the cable and connectors which are already through the hole. Is there any trouble getting to it when the panels come off? Any other tips are appreciated...
Old Feb 17, 2020 | 11:50 AM
Taking the panels off is easy, putting the upper side panels back on is not. I would not take them off as the clips break trying to get them off and putting them on. I found it impossible to do and my good frien bluecoupe got into the tribune to complete the task.
I cannot remember if that hole actually does go into the trunk.
Old Feb 17, 2020 | 12:42 PM
g wheels's Avatar
Thanks and I see what you mean regarding the plastic clips. I'll be going to United or ordering them online as it looks like a few have broken. I was going to ask you via PM but you don't answer them (at least from me) and I don't blame you. As for a hole going through from the bumper cover to the interior, that's a negative from my inspection. I'll have to drill a hole unless someone else intervenes soon. My car is so pristine for being 17 years old that I hesitate; but nothing last forever any ways. Appreciate the heads up and advice. I really want that camera as I can't get used to such a short back side. I just finished installing a camera on my FR-S and it went well but that drilling through the bodywork is a buzz kill..
Old Feb 17, 2020 | 02:06 PM
g wheels's Avatar
All is right! Removed tail light, found an opening beneath the top layer of the bumper cover. Fished a wire to the hole beneath the license plate. No new holes needed..
lewis95656
Mar 12, 2015 07:46 AM
CipherBIF
Jul 11, 2014 10:55 AM
SilverFox
Sep 18, 2007 11:11 AM
LCGI
Jan 8, 2006 05:29 AM
CalgaryX
Aug 11, 2004 02:06 AM
