CD Button on Radio Not Working?
Old Mar 23, 2019 | 03:25 PM
maggy55's Avatar
Exclamation CD Button on Radio Not Working?
Hi, When I push the CD button the radio won't change from FM to CD. If I load a disk manually it reads it and switches to CD and everything is fine. Anyone have this problem before ?
Thanks
Old Mar 23, 2019 | 07:35 PM
Default Re: CD Button on Radio Not Working?
Thanks
That is the way it works. Why would it switch to CD when there is no CD in there? What would you get if you dropped a needle onto a platter which had record on it? Damage.
Old Mar 23, 2019 | 08:27 PM
maggy55's Avatar
Okay , maybe I wasn't clear. The CD function button doesn't work even if a cd is in the radio. Before I had this problem I could listen to a cd , switch to FM and then back to the CD. Now if I switch to FM and push the CD button it does not go back to the cd. I can eject the cd and put it back in and then it will switch to the cd player. Does that make sense?
Firefly2018
Jul 13, 2018 12:09 PM
Truckboss
Oct 24, 2013 02:45 PM
toia6407
Aug 3, 2012 12:58 PM
Romio
Nov 17, 2010 09:46 AM
