Crossfire Smog pump \ Secondary Air Filter
Old Jun 7, 2022 | 05:51 AM
Dantheman204's Avatar
Default Crossfire Smog pump \ Secondary Air Filter
Hi Guys,
Engine management light came on, secondary air pump issue. I replaced it and cleared the codes (well my garage did) worked fine for a week and then light came back on. The pump itself clearly works so my garage said he needs the "schematics" to show which fuse or electrical component powers this secondary or smog pump.
Anyone know what this is or means ?
Thx
Old Jun 7, 2022 | 10:08 AM
Default Re: Crossfire Smog pump \ Secondary Air Filter
Originally Posted by Dantheman204
Hi Guys,
Thx
All things start with the actual DTC codes you had them 'clear'. Please get them & post here, we cannot offer advice without at least starting out with those. I would be wary of a garage that cannot diagnose this without a code reader that tells them what the codes are (not to mention if the pump is actually working, why do they need a schematic?). Get the exact code/codes and post them here. Good luck!
Old Jun 7, 2022 | 10:10 AM
tighed1's Avatar
Most likely code P0410. Check the contacts on the air pump relay in the relay control module. Bet that they are BURNT! May have been your problem all along. If so the relay can be replaced for about a third of the cost of a new RCM.
There's also a blue check valve that can cause issues.
Old Jun 7, 2022 | 12:43 PM
Thank you foe the response. This makes complete sense !! The garage said the similar. In ghosts response I neglected to mention that A. I am in the UK so the garage I use doesn't have the schematics for some American vehicles.
I also neglected to mention that both pumps work. What happened is that when the engine was turned off the secondary air pump stayed on !! Eventually flattening the battery. Hence bought another pump and it did the same so effectively what they wanted to know was where the module or relay for that pump was so I can replace it.
Thx
orbit398
Jun 12, 2016 03:33 PM
mvagusta10
Aug 30, 2013 12:50 AM
crookedview
Mar 26, 2013 09:22 PM
Black03AR
Jun 21, 2010 03:47 PM
wheeldealer
Mar 31, 2010 12:14 PM
