Another RCM issue-where does it get power?
Old Jun 10, 2024 | 12:22 PM
Alpha Dog's Avatar
Default Another RCM issue-where does it get power?
OK, here goes. I had the SKREEM issue so I sent the ECU to Josh @ Mercedes Swap Shop. He did an excellent repair and a hot tune as well. Reinstalled. Then I had the dreaded RCM won't crank issue. Sent RCM to djtighe1. Very quick and awesome price. Reinstalled. Car ran great. Had/have a parasitic electrical draw so I disconnect battery when not driving. I went to start it up and got the no start issue again. No crank, fan spins up to hyper speed. RCM relays do not close with key on. I'm pretty sure the RCM is good. All fuses on module are good. I guess the next step is to find where the RCM gets it's power. Does anyone know where/how to check incoming power to the RCM?
Old Jun 10, 2024 | 04:09 PM
Default Re: Another RCM issue-where does it get power?
IF you're still having a parasitic draw, have you removed the alarm siren? That's the most common draw. The batteries inside corrode and cause a short.
You can try removing the number 9 fuse in the engine fuse box. Charge the battery using a trickle charger and then see if you have the issue after that.
Old Jun 11, 2024 | 12:45 AM
Alpha Dog's Avatar
Thanks for the info. Years back I had the alarm buzzing but I dont remember if I disconnected or not. Now if you can solve my RCM issue I'll be golden😁
Old Jun 11, 2024 | 02:07 AM
I found a diagram showing where the power source for the RCM is.
I've made a picture and I'm adding a link to where I found the information. (See figure 10 in the link).
RCM info.
Old Jun 11, 2024 | 01:01 PM
Alpha Dog's Avatar
Thanks for the additional info. I found the wiring diagram but haven't completly deciphered it yet. It seems the RCM draws power from a splice block 100. Since it also supplies power to several other items, I'm assuming the block is good. YouTube mentioned to check the actual pins on the RCM connectors. I'll check my input power on the points you indicated and let you know.
Old Jun 12, 2024 | 01:49 AM
I just thought of something, that might help or not.
When I replaced mine, I had a hell of a time getting a few of the connectors off. I wonder if maybe a wire got loose on one of your connectors?
Good luck!
Old Jun 12, 2024 | 02:49 AM
Alpha Dog's Avatar
Thanks for the response. Checking the wires/pins on the connectors (as well as checking input voltage) is my next step. Can't get to it until Saturday. Just interesting that one day it starts, next day it doesn't.
Old Jun 12, 2024 | 09:16 PM
Pictures of the wiring color codes before taking the connector apart helps in case the wires get shuffled around. Do one connector at a time. One of my connectors had three defective connectors inside it (the tip separated from the crimped on connector at the 90 degree tip, result was an intermittent no start). Good luck!
Old Jun 13, 2024 | 02:07 AM
I remember that thread. I believe those connectors were available somewhere.
Old Jun 13, 2024 | 03:11 PM
It depends on the size (there are two different sizes in the harnesses on the RCM). The part I needed was THE LARGER ONE OF THE TWO (see below, I am not sure IF I also had the smaller one part number in the data. Hope this helps!
Part Type: Electrical Pin Connector
Part Number: 0035452626
Interchange: Part Number 003 545 26 26 / 0035452626
Weight: 0.01 lbs
Size: L x W x H 0.2 x 0.2 x 0.6
Part #: 0035452626
Mfg Part #: 0035452626
Interchange Parts for MERCEDES-BENZ 0015453526 (replaced by) 0035452626:
Brand:
MERCEDES-BENZ 0035452626 Contact Sleeve
HERTH+BUSS ELPARTS 50253920 Contact Sleeve
HERTH+BUSS ELPARTS 50253925 Contact Sleeve
VALEO 914123 Contact Sleeve
AUDI 447972980 Contact Sleeve
PORSCHE 99965243712 Contact Sleeve
VOLVO 1212901 Contact Sleeve
VW 447972980 Contact Sleeve
NOTE: EAN: 4026736017002
Another reference part # set:
P/N: 0035452626 Genuine Mercedes
Cross References: 0005452726
0015453526
0015453726
A0035452626
W01331642245
It has been quite a few YEARS since I needed these, not sure if the data is still correct anymore (but) someone could have them, somewhere. Hope someone can use this?
Old Jun 13, 2024 | 08:30 PM
Weight: 0.01 lbs
Part #: 0035452626
Brand:
0015453526
0015453726
A0035452626
W01331642245
Thanks George!
Old Jun 16, 2024 | 10:16 PM
Esinclair's Avatar
Hopefully I'll never need it, (I think mine may have already been worked on by DJ) but this is in my trunk now.
paulcross140
Nov 7, 2024 01:45 PM
Esinclair
Feb 11, 2024 03:06 PM
Trey05-6101
Nov 11, 2020 10:54 AM
AlexParra
Dec 29, 2016 06:17 PM
