Liftgate not locking
Old Jul 25, 2006 | 01:03 PM
stewilly's Avatar
Angry Liftgate not locking
I just discovered the rear liftgate does not appear to be locking on my 2004. I found out because I instinctively went to open it when returning to my parked car and got hit with the alarm. I then checked and have determined that there appears to be no mechanical activity at the liftgate when I lock the car. Good news is that, obviously, the alarm senses that it's locked.
Old Jul 25, 2006 | 01:20 PM
Thirteendog's Avatar
Default Re: Liftgate not locking
I do believe there was a recall on all '04 model crossfires. They replaced the liftgate latch I do believe. Give me a minute and I can give you more info.
Old Jul 25, 2006 | 02:22 PM
aschrager's Avatar
The vacuum line going to the lock is probably the cause. There is a TSB to fix it.
Old Jul 25, 2006 | 07:35 PM
stewilly's Avatar
Problem solved!! After being informed there was a TSB and checking the service manual, I realized that the sound of compressed air that I was hearing whenever the locks engage was the problem. I found a break in the yellow vacuum hose that runs to the liftgate lock inside the rubber housing at the upper right corner of the liftgate. I was able to fit a piece of tubing over each end and I now have a functioning hatch lock!! Thanks for the help.
Old May 17, 2007 | 12:17 AM
Bostonsrt6's Avatar
Hey dude can you describe what you did in order to fix this? How did the tubing work out?...sorry if you could describe this a little better for me.
Old May 17, 2007 | 02:01 PM
stewilly's Avatar
The fix has worked fine. I was fortunate that the leak was in an area of the hose that could be relatively easily accessed. You may be able to pinpoint the location by the sound. Again, rather than replacing the whole hose, I just found a piece of tubing I had around that snugly over each end after I cut the cracked hose. GOOD LUCK.
Old May 17, 2007 | 02:14 PM
Bostonsrt6's Avatar
I appreciate the help! I went to the dealer and they put shrink wrap on it for a short fix...
Mackel
Oct 16, 2015 09:03 AM
Selbyl
Sep 26, 2015 04:15 AM
Selbyl
Sep 22, 2015 10:41 PM
xjken
Sep 13, 2015 10:18 PM
crmnal
Sep 6, 2015 08:07 AM
