SRT6 Engine Transplant
Old Oct 14, 2007 | 11:07 PM
HDDP's Avatar
Default SRT6 Engine Transplant
Here's the only thing that I found interesting, so far, while transplanting the SRT6 engine into my track car...
Old Oct 14, 2007 | 11:44 PM
alfdoc's Avatar
Default Re: SRT6 Engine Transplant
If you didn't already know, charge air coolers are common on turboed and supper charged engines. They cool the compressed air from the turbo or the supper charger before it enters the intake, which makes the engine produce more power.
Old Oct 15, 2007 | 07:28 AM
ShawnQ's Avatar
I think he is likely referring to the manufacturer, Garrett, and Hecho En Mexico..?
I'm sure HDDP knew there was an intercooler on it...
SQ
Old Oct 15, 2007 | 08:26 AM
MI1XFIRE's Avatar
I'm sure is referring to the Made in Mexico.
Old Oct 15, 2007 | 09:00 AM
Maxwell's Avatar
it even looks like it was made in Mexico, look at the funky welding, lol looks like it was done with a mig.
Old Oct 15, 2007 | 02:05 PM
LantanaTX's Avatar
Are you swapping an SRT-6 engine into a n/a car?
Old Oct 15, 2007 | 02:14 PM
Coyote's Avatar
Hmmm, knew there were "other" parts in this car, but Mexico? Didn't
see that coming. Seems the SRT-6 is truly a diverse vehicle. So, why
do some of my more "progressive" friends give me crap about "all the
gas I burn". Isn't diversity itself a laudable goal? Oops... wrong forum
for that... sorry.
Coyote
Old Oct 15, 2007 | 02:50 PM
malcb's Avatar
Coyote
As a European car that's not very suppressing.
American cars = mostly US parts, Japanese = mostly Japanese.
European makers take all sorts of bits from their group of companies and mix and match. Parts from Garrett and other worldwide manufactures (Eaton etc) often end up in European cars because the better (and cheaper) specialist parts are found in the North America.
Ford Europe have Ford, Land Rover, Volvo (also Jaguar & Aston Martin) to chose parts from.
VW have VW, Seat (Spanish), Skoda, (also Maybach & Lamborghini).
BMW started making cars by selling a licensed version of an Austin and did own Land Rover.
That said that I think the diesel engine in the Dodge Caliber over here if from Japan and the Diesel PT Cruiser has a MB diesel.
As to Garret manufacturing in Mexico - is a common trend world wide, make the product where the raw material is, particularly with things like aluminum, by doing it they can add value and make the most of the resource. The Chinese are catching on that making cheap items in China say an aluminum saucepan using manpower, materials and energy, is not in China's long term interest, far better make a more valuable item and get more income.
Old Oct 15, 2007 | 03:12 PM
LantanaTX's Avatar
The engine in my Mini Cooper S was made in Brazil.
Old Oct 15, 2007 | 03:36 PM
ShawnQ's Avatar
Yes, he is doing the swap into the race-prepped crossfire he has...
SQ
Old Oct 15, 2007 | 11:03 PM
HDDP's Avatar
Correcto el mundo amigo.
I have this engine torn apart right now and it's quite interesting... One of the big HP problems I see is the charge air cooler "intercooler" is smack dab wedged in the middle of the V block (the hottest part of the engine) under the supercharger with 5/8" thin wall, un-insulated aluminum tube feeding re-circulated hot water from the engine coolant overflow tank. So, I'm having to do some re-engineering on the charge air cooler to increase the tube size to 3/4" insulated heat sink tube with a custom coolant tank and 3.5" x 6.5" x 18" heat exchanger from Bell Intercoolers and a 6.9 gpm Johnson marine pump. And also going to insulate the intercooler from the heat of the block when it's reinstalled.
Old Oct 16, 2007 | 06:35 AM
ShawnQ's Avatar
HDDP,
Do you see any feasible way to move the heat exchanger out from between the 'V', and into cooler air?
I assume that if you plan to leave it there, then you've thought out all of the options, and decided on the most cost effective way to do it to provide best bang for buck.
I'm new to 'foreign' cars, but other than this one, the only other cars I know of that had their intercooler so close to the engine were the SVO Mustangs and T-Bird turbo coupes. Even those were 'off' of the 2.3L and actually stayed fairly cool.
SQ
Old Oct 16, 2007 | 01:09 PM
x'ed's Avatar
man i can't wait to see this car when its finished.
Old Oct 17, 2007 | 11:01 PM
HDDP's Avatar
HDDP,
SQ
I'll take some photos of the interconnect between the SC and the Charge Air Cooler, but I don't think there is a feasible way to remove it from the V... There are some ways to insulate the system and reduce the heat... I'll try to document this as I progress... But the coolant system is really stupid...
I have ordered a Bell heat exchanger that is 3.5"d X 6.5"h X 18"w that will fit in front of the OEM radiator without intruding on the airflow to the radiator. Also bored the ports of the charge air cooler from the OEM 5/8" to 3/4" and ordered custom heat sink tube from cain industries to plumb the SC cooling liquid from a custom aluminum cooling tank that will be pumped by a 6.9 gpm marine impeller pump...
Old Oct 30, 2007 | 04:09 PM
HDDP's Avatar
Well, it's getting closer to install and nearly reassembled... I'm sure you'll notice a bit of difference in the appearance... Schrick cams installed, intakes ported & polished, Headers being built, intercooler system pats on the way...
Old Oct 30, 2007 | 04:14 PM
ShawnQ's Avatar
Looking good man! Polishing is a PAIN.
Did you have a chance to look closely at the headers?
It appears that they are cast, with a sheet metal heat shield around it...is this true? Or are they true tubular design?
Keep us posted on the intercooler mods you make.
SQ
Old Oct 30, 2007 | 04:46 PM
HDDP's Avatar
The manifolds are removed since this photo and will never see this engine again And yes, they seem to be sleeved with an outer shell...
Old Oct 30, 2007 | 04:50 PM
HDDP's Avatar
And here are some photos ot the Charge Air Cooler...
Old Oct 30, 2007 | 05:05 PM
HDDP's Avatar
And here's the SC after a little work... Still not finished though
Old Oct 30, 2007 | 05:19 PM
ShawnQ's Avatar
Excellent pics again!
Did you modify the pulley, or just took a pic of it? I've never really looked too hard at my S/C as I'm worried that I'll start digging around and messing with it (and subsequently my warranty).
Keep us posted on your header design.
SQ
