SRT6 Engine Transplant
Old Nov 1, 2007 | 08:23 PM
  #41 (permalink)
HDDP's Avatar
Default Re: SRT6 Engine Transplant
By The Way, could you have imagined 1.5" exhaust ports ? No wonder this engine only makes 330 hp out of the box...
Old Nov 1, 2007 | 08:30 PM
  #42 (permalink)
Sidez's Avatar
Derick I just want to say thank you for doing this even though you prolly are not doing this for us.. there is just so much we can learn from... from such a conversion
and yes about those exhaust manifolds.. yes they are horrible.. hopefully after your conversion you will have a seriously dangerous crossfire..
PS. All this recent talk about engine conversions and upping horsepower that has sprung up in the recent times makes me regret spending my project money on rims first(******* over $5000 with tires), and instead of the engine ,but I am damn sure I will get to it so i can roll with you guys
Old Nov 1, 2007 | 08:37 PM
  #43 (permalink)
HDDP's Avatar
PS. (******* over $5000 with tires),
OUCH !
But don't regret anything... I'm going to be into this engine transplant over 10K before all is said and done... Not including my time... That is providing the manual tranny works... And the MOTEC M600 works !!!
This is a MESS
Old Nov 1, 2007 | 08:52 PM
  #44 (permalink)
Maxwell's Avatar
looks like another mercedes heat exchanger project going on over at MBworld
http://www.mbworld.org/forums/showthread.php?t=213966
Old Nov 1, 2007 | 09:14 PM
  #45 (permalink)
Maxwell's Avatar
I think this is a decent size exhaust port, I would focus more on the intake valves first, as that is more important area to port than the exhaust side. don't screw up the casting by laying into it with a die grinder, you should do it with a cnc porting machine, otherwise your gonna F@#$ up a good set of heads
Old Nov 2, 2007 | 07:41 AM
  #46 (permalink)
LantanaTX's Avatar
OUCH !
This is a MESS
Fun being a pioneer isn't it? I have been trying to buy the parts right in case I end up having a giant garage sale.
How did Sidez get the F word to work? I can't even get ******* to work which isn't evena bad word?
Old Nov 2, 2007 | 09:03 AM
  #47 (permalink)
ShawnQ's Avatar
Lantana,
that word is not in the filter (surprisingly)...
Nice work guys. Keep it up.
SQ
Old Nov 2, 2007 | 09:50 AM
  #48 (permalink)
HDDP's Avatar
He has a really sound idea by trying to chill the coolant... I can't agree more... The OEM system is a really weak design...
Old Nov 2, 2007 | 09:54 AM
  #49 (permalink)
HDDP's Avatar
It's all about the parenthesis' (S H I T) and spaces ... But we really don't need expletives for our posts unless we're talking about Chrysler Service
Old Nov 2, 2007 | 10:05 AM
  #50 (permalink)
HDDP's Avatar
I'm not going HOG WILD on the exhaust ports right now... I do not want to take the engine down to bare parts yet... I'll probably breakdown the other N/A engine and send it to "Extrude Hone" after I get this one working...
First priority is to get this engine into the car, see if the manual transmission bolts-up. and getting the Motec installed and operating...
Old Nov 2, 2007 | 11:32 AM
  #51 (permalink)
ShawnQ's Avatar
HDDP,
Any estimates on when you'll have it together and ready for testing/tuning?
When do you plan to stab the trans?
SQ
Old Nov 2, 2007 | 04:20 PM
  #52 (permalink)
HDDP's Avatar
Originally Posted by ShawnQ
HDDP,
SQ
Well, if the WGA writers strike happens on Monday, I'll be locked-out of work That means two things... I'll have lot's of time to finish the project and lots less money to finish the project... So, in answer to your question, I would safely say Jan 1 ...
Trust me, I'm as anxious to get this thing finished as many members are to hear the results of this FRANKENSTEIN experiment... The new NASA season begins in late February and I need at least a few track testing days prior...
The good thing is that I already have the new heat exchanger, fin tubing, IC pump, Schrick cams, Spec Clutch and built the wiring harness' for all the sensors... The bad thing is that I haven't purchased the MOTEC M600 yet, but Brian Sakata has it in his shop waiting for my measly $4,500
And GOD knows how long it will take him to make the engine work with the new computer...
Old Nov 4, 2007 | 08:57 AM
  #53 (permalink)
Maxwell's Avatar
Yo H, just for research purposes, what size is the throttle body on the srt6?
I was reading on some MBZ forum that the SL55 is 80mm. not sure if they are compatible with NA motors or blow srt6?
Old Nov 4, 2007 | 09:02 PM
  #54 (permalink)
HDDP's Avatar
I just happened to have it sitting on my bench... Looks like 74mm ID on both sides...
Old Nov 4, 2007 | 09:12 PM
  #55 (permalink)
HDDP's Avatar
BTW... This is what I originally signed on to post on the forum tonight... Here is the heat exchanger that I designed for the SRT6 engine... I, with the expertise of Gerhard Schruff of "BELL INTERCOOLERS"... It should be delivered in two weeks...
Old Nov 5, 2007 | 12:04 AM
  #56 (permalink)
jonnyangel04's Avatar
THat is a VRP after market throttle body that is 80mm... That is why you have to special order the 80mm CF box from him if you have vrus intake instead of the 70mm box. I believe the 55s are the same size as ours which is considered a 70 or a 75 i have heard both..
Old Nov 5, 2007 | 07:42 AM
  #57 (permalink)
Maxwell's Avatar
interesting, good to know. yet I wonder if there are any power gains with the VRS throttle body, I'm willing to bet that there is more flow restriction on the intake ports that the 80mm TB makes no difference.
Have you been able to find any flow numbers or dyno graphs from VRS?
Old Nov 5, 2007 | 07:45 AM
  #58 (permalink)
MMZ_TimeLord's Avatar
HDDP,
That looks like an awsome intercooler! I love the double-back flow route... it should really cool down the liquid.
Great job... keep it coming bro!
Old Nov 5, 2007 | 09:29 AM
  #59 (permalink)
HDDP's Avatar
Originally Posted by MMZ_TimeLord
HDDP,
The flow route will be from the new (ice tank) directly into the OEM charge air cooler, out to the Bell heat exchanger which will be located in front of the OEM radiator and then back to the tank... I still haven't determined where to locate the tank, but I have 12' of "fin tubing" coming from Cain Industries which is enough to put the tank anywhere in the car... Except, the Johnson pump has a limitation of three feet to maintain 6.9 gal. per min. It might turn-out that I'll need two pumps if I locate the tank in the cockpit... I've been trying to see if there is a way to relocate the inlet of the OEM charge air cooler to the rear, without cutting it open, this would allow a direct flow from the tank in the cockpit then out to the heat exchanger in the front...
Old Nov 5, 2007 | 09:52 AM
  #60 (permalink)
HDDP's Avatar
a 75 mm inlet at 100 mph airflow would be 1673.91 ft3/min CFM
a 80 mm inlet at 100 mph airflow would be 1904.54 ft3/min CFM
Fueling would have to be increased by a minimum of 2 % otherwise a lean state would occur and no hp gain would be realized... Unless you can manipulate the ECU to reduce AFR from it's pre-programmed state of 14.7:1 you are wasting your time and money...
But if you are capable of adjusting the fueling and timing maps, then this will definately result in a minor HP gain...
