radio antenna on roadster
Old Dec 14, 2007 | 06:00 PM
woodlands1's Avatar
Default radio antenna on roadster
Has anybody installed an aftermarket antenna on the roadster? I'm not too keen on the wrapped wire look and would like to replace the OE antenna.
I have seen short (4-6") antennas for sale on the bay and wonder if they will have the same ability to bring in stations that the OE antenna does?
Anybody have any ideas? Thanks.
Old Dec 14, 2007 | 07:46 PM
maxcichon's Avatar
Thumbs up Re: radio antenna on roadster
Originally Posted by woodlands1
Has anybody installed an aftermarket antenna on the roadster? I'm not too keen on the wrapped wire look and would like to repalce the OE antenna.
CTD Germany has some different ones.
http://www.ctd-germany.com/shops/cro...op_e/index.php
Old Dec 14, 2007 | 10:15 PM
CrossfireLTD's Avatar
Cool Re: radio antenna on roadster
I have 2 different after market antennaes that I use, see pics below. I switch back and forth as the mood hits, no radio distortion or signal loss from either.
CTD - Germany comes with 3 different shafts about $32.00 US
Beesting Antennae from Ebay $22.00, exactly the same as the pic below of the CTD - Germany 24V antennae.
Old Oct 9, 2018 | 03:05 PM
cheyoru's Avatar
Default Re: radio antenna on roadster
Hi there! I realize this is a pretty old post but does anyone have a more updated suggestion for a radio antenna with a low profile? My stock antenna is in pretty bad shape. Also, my srt6’s color is aero blue Thanks in advance!
Old Dec 18, 2018 | 11:37 AM
NeedsWings's Avatar
bump for a new solution, got a customer needing a new base, anyone got one for sale?
Old Dec 18, 2018 | 12:50 PM
If you mean the gasket then someone said a VW one fitted perfectly. If it is the main body then a look at the old one should give a number to try. These parts are off the shelf items if you know where the shelf is. LOL
Old Dec 18, 2018 | 12:51 PM
Raynger's Avatar
Ebay - free shipping $9.39
Car Radio FM Amplified Booster Antenna for BMW Z3 Z4 M3 Toyota VW Passat B5
https://www.ebay.com/itm/20145629546...&s=ci&mail=sys
Old Dec 18, 2018 | 06:38 PM
Yea, but out of stock!
It sure looks like the OEM part, tho.
Old Dec 18, 2018 | 08:31 PM
RED DOG's Avatar
The same antenna with base appears to be available from some other E-Bay sellers.
https://www.ebay.com/itm/For-BMW-Toy...xHBQ:rk:2:pf:0
https://www.ebay.com/itm/Car-Vehicle...xD8L:rk:6:pf:0
Here's the base only . . .
https://www.ebay.com/itm/ROOF-MAST-W...tege:rk:8:pf:0
These have been discussed before . . . The problem is that the connector is different that what is needed to hook up on our Crossfires. There is no (easy) way to change the connector. Anybody have the answer??
Old Dec 18, 2018 | 08:39 PM
RED DOG's Avatar
If you just want to replace the rotted rubber gasket . . . This is what you want:
https://www.ebay.com/itm/Roof-Antenn...Am~Q:rk:6:pf:0
https://www.ebay.com/itm/Antenna-Bas...AmDk:rk:2:pf:0
Old May 17, 2023 | 02:44 PM
NeedsWings's Avatar
can i please get some insight on what to do about the 2 wire to 1 wire conversion.
Old May 23, 2023 | 08:51 PM
I'm new to the forum and the Crossfire car itself and I'm looking for some advice.
The gasket on my antenna base is cracked and I was looking at a VW Jetta gasket. It looks like the gasket is a little thicker than the Chrysler. Has anyone ever used one to replace the original?
I've included some pictures.
Thanks for any advice or info in advance.
Old May 24, 2023 | 03:07 PM
Probably will work. This Amazon Link says the Gasket is compatible with Chrysler / Porsche / VW.
CLICK"><span style=CLICK" /> CLICK">CLICK
This website is a good source for Chrysler Crossfire Roadster antenna hardware - CLICK.
Old May 24, 2023 | 04:08 PM
Thanks for the info and links!
Old May 24, 2023 | 07:23 PM
NeedsWings's Avatar
has anyone installed that base with just 1 wire? how is the reception changed?
Old May 29, 2023 | 12:28 PM
I just got this from ebay. I haven't put it on yet, but it looks like the correct gasket. It comes with a 9 inch antenna, but I'm using the standard 16 inch antenna on my car.
https://www.ebay.com/itm/185788980818
Last edited by M60A3Driver; May 29, 2023 at 12:33 PM. Reason: additional information
Old Sep 19, 2023 | 12:08 PM
type dougie's Avatar
@M60A3Driver Was this the correct gasket?
Old Sep 19, 2023 | 04:38 PM
Looks like the one I used in 2019 when I replaced mine.
Old Sep 20, 2023 | 02:41 AM
@type dougie Sorry, I still haven't put it on yet. I'm stock piling parts for winter. I'll be living in my garage until spring replacing parts LOL.
It looks like the original and the seller, lightning-fast-crossfire-parts, has 100% feedback. He sells mainly Crossfire and SLK parts.
All of his feedback comments indicate that it is correct. If you click the link and scroll to the bottom you can read them.
Old Nov 22, 2023 | 10:48 PM
@type dougie
I replaced the gasket today. It's a little different than the stock gasket, but I think it's a better quality.
Abaton6
May 16, 2013 08:42 PM
Traveler
Oct 5, 2012 07:36 PM
jonnyb
Nov 18, 2010 06:56 AM
boostwhore
Oct 29, 2009 03:56 PM
brain_26
Jul 5, 2009 01:00 PM
