Fuel Door won't stay closed?
Old Feb 18, 2009 | 08:11 AM
ShawnQ's Avatar
Default Fuel Door won't stay closed?
Hey guys,
A co-worker of mine has an SRT-6 and asked me if I knew any reason why the fuel door wont stay closed/latched?
When you press on the door, the 'plunger' goes in like it is supposed to, but the door itself doesn't latch.
There is a tab sticking off of the door that has a hole in it - it appears as if a part is missing, but I'm not sure.
Is there a schematic for the fuel door, or something that I can look at to try to figure this out?
Is this a known issue?
Thanks,
Shawn
Old Feb 18, 2009 | 09:16 AM
AlG's Avatar
AlG
Default Re: Fuel Door wont stay closed?
The hole is there because that's where the pin from the central locking goes through to keep the door locked. It's possible that that part of the system is not working. You can check by leaving the door open and locking the car with the fob and seeing if the pin comes out. If the door was closed it would go through that hole.
Old Feb 18, 2009 | 09:31 AM
Originally Posted by ShawnQ
Hey guys,
Thanks,
Shawn
It only locks when the car is locked, it is operated by an air line which could be broken. Or do you mean that it pops up rather than stay flush? In that case I would say that the hinge spring is broken.
Old Feb 18, 2009 | 09:49 AM
ShawnQ's Avatar
AIG,
Thanks - I figured it out after you explained how it worked.
Apparently the locking 'PIN' wasn't lining up with the hole in the gas lid.
I got to looking around, and the tether that holds the gas-cap to the car was spun and twisted so bad it prevented the lid from closing all the way. When you went to lock it, the pin would then mis-fire and wouldn't make a positive latch.
I 'unwound' the tether, and now the door lays nice and flush with the body and the locking mechanism functions again.
Thanks for the help,
Shawn
Old Feb 18, 2009 | 11:13 AM
ZAHANMA's Avatar
AIG,
Shawn
That is exactly what happened to me... I was about to take it in to the dealer and b*tch at them... Then luckily I figured it out prior...so I saved face a little. This seems to be the most common problem the the fuel door is the gas cap rubber string...or whatever its called... Now that I know what it is, I'm much more aware of it when filling up my tank and such...
glad everything got resolved.
Old Feb 18, 2009 | 11:57 AM
OKC-XFR's Avatar
My gas cap tether kept getting in the way until it broke from being pinched so much! Now it's on my list of warranty items to have taken care of...
Old Feb 18, 2009 | 02:54 PM
apkano's Avatar
Life is random...so am I.
Damn......you guys are pretty good. I was gonna suggest the tether being in the way, but you all beat me to it.
I did have a second plan of action though.........
Old Feb 18, 2009 | 03:42 PM
billangiep's Avatar
Naaa....This would have made a much faster repair with no pre-drilling required !
Old Feb 18, 2009 | 04:23 PM
OKC-XFR's Avatar
I have only 2 words: DUCT TAPE!
Old Feb 18, 2009 | 07:15 PM
MikeR's Avatar
EXACTLY! and it is aerodynamic.....
MikeR
Old Jun 26, 2013 | 01:35 PM
LadyMills's Avatar
Mine is doing this now. I noticed yesterday the rubber tether broke, but it didn't seem like there were any pieces wedged anywhere. My plunger is working fine, and i can close the door all the way, but it won't stay. It pooches out just a little bit - it's not catching. It almost looks like a piece is missing from the latch? Did a piece break off somehow?
EDIT - nevermind. I realized the piece that was still connected to the door was just the perfect length that it would stick itself backwards into the hinge of the gas door. I ripped it off and voila - it works now.
Old Jun 26, 2013 | 03:07 PM
rayth's Avatar
I was thinking maybe you just don't know your own strength and tore something important off in a Hulk-like rage
Old May 30, 2023 | 09:52 PM
Brendon44's Avatar
AIG,
Shawn
And where exactly can you find this tether I’m having the same issue?
Old May 30, 2023 | 11:29 PM
copperfieldkid's Avatar
Default Re: Fuel Door won't stay closed?
The 'tether' is attached to the gas cap. But just to be clear here's a photo:
Old Jun 1, 2023 | 09:08 PM
Drow's Avatar
Open the fuel door and post a pic
Old Jun 5, 2023 | 11:47 AM
ORL-XFR's Avatar
My tether recently broke - found a replacement on Amazon that fits:
Amazon Amazon
freygreer
Mar 29, 2016 11:10 AM
amusedpen
Apr 24, 2009 09:09 AM
aptiva
Dec 11, 2006 12:08 PM
dobro
Aug 5, 2006 04:33 PM
mouserider
Jul 26, 2003 11:47 PM
