Convertible top cover Cleaning
Old Nov 22, 2010 | 09:32 PM
KrazyJ's Avatar
Question Convertible top cover Cleaning
Ok I give. I'm new here and must not be using the right words but I'm sure its been covered.
What is the best way to clean the painted surfaces that cover the top when it is open?
Thanks,
-j
Old Nov 26, 2010 | 08:49 AM
Default Re: Convertable top cover Cleaning
Are you talking about the strip where the top sits?
Old Nov 26, 2010 | 08:56 AM
bmorgan's Avatar
Uh.... A wash mit with a good car soap and water.
Old Nov 26, 2010 | 09:40 AM
I'm lost for words here....lol
Old Dec 1, 2010 | 08:08 PM
KrazyJ's Avatar
im reffering to the painted section that is below the back window when the top is up. Soap and wash mit.. i get that.. do i just put the top down and be careful not to get soap and water in the car or is there another easier way to clean this section?
Old Dec 1, 2010 | 08:54 PM
awilson40's Avatar
I figure that you are never going to be in nasty weather with the top down so that area is going to stay pretty clean. I would just go over it with detail spray to clean and wax it once in a while.
Old Dec 1, 2010 | 09:12 PM
Well, that's what I do.... a wash mit and Mequiars' car wash shampoo and conditioner - I use it on the whole car. Andy is right, probably some detail spray and a applicator towel is all that is needed, but I am COMPULSIVE about washing my car!
But just be careful, I allowed a LITTLE water to trickle down to those two connectors and five wires that plug into the assembly in the gas tank... corroded the wires and gave me a false indication of high tank pressure - turned the ENGINE light on! Only took 20 mins to clean the connectors and fix it, but still...
Old Dec 8, 2010 | 03:25 PM
05roadsterguy's Avatar
There are a couple of methods for washing the rear fairing that I use. # 1 has alredy been mentioned. Just meguires detailer and a microfiber towel for weekly washings!
#2 For those times when perhaps ou might have been rolling down a gravel or dirt road and then run into a light spring shower, or a @#$#$%&#@ seagul uses your car for target practice. Raise the rear fairing to it's vertical position. place painters tape across the underside of the latch hole. place towaels into the drop zones for the edges of the fairing. lower fairing back to It's horizontal position. take a pitcher of water or water bottles to rinse the car with and carefully wash this area and then dry it.
Mission accomplished! Here in the great pacific northwest, We tend to get many variable weather mini climiates on a short drive. I use method #2 at least 6-7 times a Year.
Good motoring to All and Merry Christmas!
Herman and Laurie
ZERACER
Jul 7, 2020 10:21 PM
Hoppy
Dec 7, 2018 07:36 AM
PimpDaddy
Sep 29, 2016 11:55 PM
Indelibility
Aug 27, 2015 10:21 PM
mike28117
Jul 17, 2015 01:59 PM
