Opinions on Crank Pulley Please!
Old Sep 23, 2013 | 03:18 PM
sk8erjosh09's Avatar
Default Opinions on Crank Pulley Please!
I decided to research through google what bad crank pulleys could look like and symptoms and such. Well I would like the opinion's of people on the forum. Here are some pics and videos. Any thoughts?
At first I thought the entire pulley was "wobbling" but now I think that the (elastomer??) rubber ring is just not flush around the entire thing. When I felt it, it felt strong and.... Rubbery? lol The feel matched the look I guess is what I'm trying to say. So am I tripping out or is there really a problem?
Oh, and ignore the coolant spray everywhere... My water pump will be up for examination this weekend... I already found 1 bolt missing!
VIDEO0125_zps28a2ccd4.mp4 Video by sk8erjosh09 | Photobucket
VIDEO0126_zps357a5f2c.mp4 Video by sk8erjosh09 | Photobucket
Old Sep 23, 2013 | 03:48 PM
MoparFreak69's Avatar
Default Re: Opinions on Crank Pulley Please!
In my opinion the harmonic balancer looks like it is fine. Typically when balancers start to have problems the outer ring will walk off the inner ring, which is bolted solid to the crankshaft. Yours appears to be running true and isn't wobbly like some can get with partial separation. The rubber looks slightly dry, but isn't cracking horribly like a tire that has sat out in the sun for decades. I would run it, but I would give it a good inspection after every oil change.
Just my $.02
Old Sep 23, 2013 | 03:55 PM
Just my $.02
Can I lightly tap that ring back in where it's coming out? It was hard to get a video of what looks like wobble. In person it looked a lot rougher. I could just be seeing things.
Also, if it's "not that bad but check on it" could I just replace it with the V6's? They are the same size from what I gather.
Old Sep 23, 2013 | 04:09 PM
The rubber ring likely wont move as it is bonded to both of the rings. If you want to put the one from the V6 on there shouldn't be any problem as long as the diameter and mount bolt pattern is the same. They are more prone to having the outer ring spin in relation to the inner ring than anything. It won't cause any problems on these engines because you wont be using any timing marks on it to set base timing.
Old Sep 23, 2013 | 04:23 PM
I appreciate all the help. Couple more questions.
If the bolt is the same from V8 pulley to V6, can I re-use the bolt? Another thread was saying it needed to be a new bolt if you put on a pulley.
How in the hell can I keep the flywheel from moving when trying to break the sucker loose?
Old Sep 23, 2013 | 04:51 PM
With this puppy :
Old Sep 23, 2013 | 04:53 PM
BUT HURRY !!!
There's a "last one" on ebay now CHEAP :
Miller Tool 9102 Flywheel Lock 3 2L Crossfire Vehicles | eBay
Old Sep 23, 2013 | 04:59 PM
With this puppy :
BUT HURRY !!!
I was hoping there was an easier DIY kind of thing lol. To use that tool you have to pull the starter. It's a PITA!!! I have 3 flexplates sitting in the garage, maybe I can have my welder friend make me a tool to use at the inspection cover of the trans since the problem isn't too serious.
Old Sep 23, 2013 | 05:37 PM
Is there room to get an impact gun in there?
Old Sep 23, 2013 | 05:42 PM
Only if I pull the motor or pull the radiator lol. The latter being a maybe.
Old Sep 23, 2013 | 05:50 PM
Duh, I forgot, you are 2 cylinders longer than normal!
Do you have access to a lift or some wheel ramps to get the front of the car high enough to use a long breaker bar? There should be enough compression to allow you to yank the breaker bar sharply and quickly to break the bolt free. Might take a couple attempts, but should be feasible. Tightening will be a bit more difficult, but should not be impossible.
Old Sep 23, 2013 | 05:55 PM
If I take out the fan and shroud I could try that. With the breaker on through the top I only had ~4in of play. I didn't bother trying to yank in any direction. But I can give it a shot with everything out of the way. Thanks again for all the help!
Old Sep 23, 2013 | 08:31 PM
JEFASOLD's Avatar
The fan and fan shroud come out without tools, just unplug electrics, pull 2 clips at the top and gently lift it out. A short impact wrench should then fit in there and should do the job. And yes, you need a new bolt every time. It is a special stretch type when torqued, good for one use only.
Old Sep 24, 2013 | 09:40 AM
You are forgetting I have the V8 and a mechanical fan . The added length is way too long to fit any impact gun I have seen.
If I replace it I will buy a new bolt though.
Last night I pulled the fan and belt, I thought I fixed the leaks from the gasket on the water pump so I put the belt back on and I couldn't see any wobble at all from anything. Can't really explain why, because I would have thought the belt would pull itself into alignment but I guess not?
Anyway, one thing down now on to the water pump!
rmcdaniel12
Nov 4, 2015 04:08 PM
4drturbo
Oct 2, 2015 12:58 PM
Oct 1, 2015 01:42 AM
Sep 26, 2015 10:21 PM
Sep 25, 2015 02:16 AM
