Transmission Help Pleaseee!!!
Old Nov 1, 2013 | 09:41 PM
tje275's Avatar
Exclamation Transmission Help Pleaseee!!!
My main question is will too much transmission fluid cause my shifting to be sluggish and sloppy? Some background information is that my car had a R&R done on the transmission about 45,000 miles ago, shifted fine until recently. First thing to start with is, I checked the fluid and it's like a yellowish color instead of a pink, so first thoughts are they put the wrong fluid and it's degrading or what not. Next I used a transmission dipstick and I/R gun to check the fluid level, at 130degrees it showed over 65mm, the chart says it's supposed to be at 42mm, and even when I checked it cold it was that high. Also apparently after reading every thread on here about transmissions and fluids, etc. I found out that the dipstick is supposed to go at least 28inches before it hits the bottom of the transmission tank but I can only get 25 or 26 inches before it touches, and I followed the manual and the threads on how to properly check the level, so I'm not sure what I'm doing wrong if anything. Any suggestions or advice would be greatly appreciated thanks, you guys have helped greatly in the past hope you can this time
Old Nov 1, 2013 | 09:42 PM
tje275's Avatar
Default Re: Transmission Help Pleaseee!!!
Also the breather/vent, on top of the transmission has leaked a tiny bit of fluid here and there acting like the fluid is too hot and foaming up I guess, not sure just going off what I have read thanks
Old Nov 4, 2013 | 06:52 PM
tje275's Avatar
Anybody have any ideas.........
Old Nov 4, 2013 | 07:12 PM
velociabstract's Avatar
I did a quick google search and what I came up with is Pentosin ATF. It's a yellow color and Pentosin says it's for our MB transmission. I've had shifting problems from low fluid, unfortunately I can't tell you what high fluid levels shift like. Look at and smell the fluid, if it's not milky (water contamination) or smells burnt the fluid is still good. If you see foam or bubbles it may be overfilled. My thoughts are that if grossly overfilled you wouldn't have lasted 45,000 miles. If positive it's too full, the fluid looks and smells normal, use a long clear hose and suck some out.
Les
Old Nov 5, 2013 | 09:17 PM
tje275's Avatar
Les
Thanks for the input Les, I did some more research and found that to much fluid causes foaming which then cause decreased pressure to vital transmission areas causing bad and sluggish shifting sometimes. The only thing I'm concerned about now at this point is why it never felt this way for the past 45,000, which leads me to think it was the wrong fluid used and has degraded or burned and gone bad causing the foaming, so I I may perform a transmission flush and put all new fluid in and the right fluid level and see how it performs after that. Would I need to replace the trans filter or do you think just the flush should be sufficient enough to get all the other fluid out? Thanks for the help
Old Jan 17, 2018 | 02:16 PM
glover's Avatar
Hi all. I have a 2004 Crossfire auto. Had a recent transmission fluid and filter change.
I now have oil leaking from transmission and suspected the sump gasket but garage says that it appears to be coming from the breather vent on top.
Any help would be greatly appreciated.
Thanks
Old Jan 17, 2018 | 02:18 PM
If the pan gasket is indeed OK, and they properly replaced the electrical connector body and O rings ( as they should ), then they most likely overfilled it.
Old Jan 17, 2018 | 04:02 PM
waldig's Avatar
Talking Re: Transmission Help Pleaseee!!!
I over filled my transmission and it blew off the excess over the side thru the vent it seems to know what it wants. Found that interesting, after my O ring fix write up. Over fill does not cause shifting issues from my experience. I also made a write up showing how to make a long zip tie into a dipstick for checking the level. Worry not level is not going to damage it, Woody WDY
Old Jul 5, 2018 | 09:46 AM
Fla_Xfire_SRT's Avatar
Is there a link to this -Zip Tie Dipstick - write up? Thanks in advance.
Old Jul 6, 2018 | 08:21 AM
waldig's Avatar
I found my posting, I used a zip tie - white that was narrow enough to slip in the tube.
https://www.crossfireforum.org/forum...n-problem.html
Enjoy, Woody
syfi
Mar 28, 2026 04:14 PM
UNDER PSI
Nov 1, 2015 09:39 PM
Oct 1, 2015 01:42 AM
rfourt
Sep 25, 2015 01:38 PM
atdavis2
Sep 21, 2015 01:25 PM
