Going to purchase a sub
Old Mar 18, 2014 | 07:56 AM
hlocklear's Avatar
Default Going to purchase a sub
I'm planning to purchase a subwoofer soon. What size would be best to fit my 2004 crossfire? And what brand is best but not too expensive?
Old Mar 19, 2014 | 04:17 PM
hokkabaz's Avatar
Default Re: Going to purchase a sub
"-Boss BP6.8 - No modification - direct fit*-Lanzar VW64 - No modification - direct fit*-Pyramid WX65X - No modification - direct fit*-MTX Audio RTX658 - No modification - direct fit*-Boss Audio NP6.4 - No modification - direct fit*-Earthquake Sound SWS-6.5X - No modification - direct fit*-Crossfire XS M6 6" XS - No modification - direct fit*-Kicker CVT654 - No modification - direct fit*-Tang Band W6 - modification and cutting required-Ultra series LV 6 - modification and cutting required-JL Audio 6W3v3-4 - - modification and cutting required*-DD Audio SW6.5 - modification and cutting required-RE Audio XXX6.5C - modification and cutting required-Peerless SLS 6.5 - modification and cutting required-CDT Audio CL-6MSUB - modification and cutting required-CDT Audio M6+ - modification and cutting requiredBest overall sounding in no particular order & requires modification and cutting."
Copied from 'Choppy's post. If you need more detials, topic is on the first page, few topics below yours...
Old Mar 20, 2014 | 12:48 AM
syfi's Avatar
Going by that list will still involve some kind of modification of the sub cage. I don't think we've ever found a direct "plug & play" woofer simply because the magnet on the OEM subs are so narrow/round, unlike any other sub. You usually have to do some dremel work on the cage to make room for the larger magnets on all the aftermarkets. And I'm not sure if those stating no modification/direct fit are actual dual voice coil 4 ohm rated, that is if you're still running the OEM amp.
Geez....now I'm confused!
Old Mar 20, 2014 | 09:56 AM
cg80's Avatar
Exclamation Re: Going to purchase a sub
Used the Pyle 600W, 32oz. magnet... minor dremel modification to fit the larger magnet...direct fit...Maxcichon was my mentor...very inexpensive and a good solid bottom end sound... a separate sub amp would probably enhance the sound even more; I stayed with the OEM... probably will add one since I like my music on the loud side from having been a member of a heavy metal band in the late 80s early 90s...Carl
Old Mar 20, 2014 | 10:00 AM
Keep fiddling with that LOUD stuff and you'll grow hair all over your body and go deaf. ( like Max )
Old Mar 20, 2014 | 10:10 AM
cg80's Avatar
Hey ala-xfire: what's going on... it must be working...have hair all over...am rather old...hearing has been affected... but... love it that way...my theory is that you only go around once,so why not do it the way that makes you happy...Carl
Old Mar 20, 2014 | 10:14 AM
+1 to whatever stokes your fire.
I guess I'm weird : I hardly ever turn the thing on, and when I do it's for NPR or an audio book from librevox ......
I love my old Alpine mostly because of the old 60's style digital clock
Old Mar 20, 2014 | 01:39 PM
cg80's Avatar
ala-xfire : Don't label yourself as weird... your're a unique individual...with personal tastes,likes and dislikes...it has nothing to do with anyone else...it's who you are...wear it as a badge. The beauty of being your own person, regardless of what others think is that opposites can be friends...BTW, what is your first name...I'm a "name" person...Carl
Are you going to the April Dragon?
Old Mar 20, 2014 | 02:16 PM
Most people on this forum know : George.
And unfortunately I won't be making that get together.
Old Mar 20, 2014 | 04:19 PM
Mrmiata's Avatar
So your stereo has the little "flip" rolling digits huh..
Old Mar 20, 2014 | 09:57 PM
maxcichon's Avatar
Hmmm....I don't know what to say. The boss does trim my ears during my hair cuts.
It's actually taking longer for the ears than the rest of the head these days...
Mine sounds pretty good. I have a small amp installed for the subs. I CAN over drive them.
And it sounds WAY better since I wired them in parallel (2 ohms) and in phase with each other. This allowed me to change phase and sync with the front speakers. Now, instead of a series of thuds, I get one harmonious thump!
Sterling57
Apr 11, 2016 06:11 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
debradegiovanni
Sep 27, 2015 09:39 AM
cdcrone123
Sep 20, 2015 10:02 PM
Power Sedan
Sep 20, 2015 09:24 PM
