ESP pressure sensor 1
Old May 10, 2014 | 11:38 AM
meaty62's Avatar
Default ESP pressure sensor 1
Hi all
Have the dreaded esp/bas light on, intermittently, have had the codes read with the result C1141 pressure sensor current - 008 + zero point and offset of stored component B34/1 (ESP pressure sensor 1)
anybody out there any idea? have renewed brake pedal switch. Car runs ok when light is on, seems less likely to illuminate when started with foot on the brake pedal.
would help if I knew where esp pressure switch 1 is located
never posted before hope this is correct etiquette
Thanks
Old May 10, 2014 | 12:33 PM
Default Re: ESP pressure sensor 1
Originally Posted by meaty62
Hi all
Thanks
Intermittent could mean a bad electrical contact, pull connectors apart and see if they are clean.
There are two pressure sensors on the master cylinder. Look at them.
Look at the Service Manual (click). Down load it for future reference.
Old Jun 9, 2014 | 03:29 PM
meaty62's Avatar
Thanks for the info.
printed off relevant pages of workshop manual found out esp pressure switch 1 is mounted on the master cylinder. cleaned connections etc, still the same. purchased second hand slk master cylinder with sensors, replaced sensor, bled brakes- no esp light so far! cost £25 and some brake fluid.
Thanks for your help
rampntlion
21
Feb 11, 2019 08:18 AM
Reliableron
Oct 17, 2015 10:19 PM
stelrz1
Sep 21, 2015 11:18 AM
bobbie
Sep 12, 2015 12:49 PM
lazorouss
Sep 11, 2015 09:16 AM
