Transmission leak for Automatic
Old Jul 25, 2015 | 12:23 AM
Crossfireconv08's Avatar
Exclamation Transmission leak for Automatic
Hi folks. We have a transmission leak in our 08 Crossfire convertible. I heard this was a common issue, and wanted to get pointers as to if we should look for this in the future. We are already getting parts for it but I want to be sure they are getting the right ones. I was told on the main Facebook page for crossfire owners that if it is the connector plug just replace the plug and O ring and refill the transmission fluid. We just found out about the leak today when we where going to get an oil change "Mobil 1 5-40 Formula M" Spec 229.5. Any tips and advice are appricated and as always thanks for the help.
Old Jul 25, 2015 | 09:54 AM
Bill F's Avatar
Default Re: Transmission leak for Automatic
file:///C:/Users/User/Downloads/SB_21_002_05_Transmission_Leak%20(1).pdf
Old Jul 25, 2015 | 09:58 AM
Thanks Bill. We have ordered the parts and they are going to be here pretty soon. Thanks!!
Old Jul 25, 2015 | 04:10 PM
If you jack up the passenger side high enough to put a couple of stands in, the transmission fluid ( well, most of it ) will go to the driver's side away from the connector.
You will still get an ounce or two of spillage, but not a steady stream.
BE CAREFUL WITH THAT LITTLE 8MM BOLT THINGEY, DON'T OVER TIGHTEN !!!!
Old Jul 25, 2015 | 09:31 PM
syfi's Avatar
Here's a link to a pdf file that contains links to 6 utoob vids that show how to repair the 722.6 tranny. Extremely informative and a must watch....
Mercedes 722.6 Transmission Shifting Problems - 6 part videos.pdf
Old Jul 30, 2015 | 12:11 PM
The main culprit right now seems to be the case connector. The leak was at the front of the tranny as it so happens so that's what I'm thinking. We are going to replace the O ring and the case connector. We are currently waiting for everything to cool down since we just arrived at the shop. Thanks everyone for you're input and thanks Syfi for the link to the video on the transmission. That helped us a lot. Thanks!!!
syfi
Mar 28, 2026 04:14 PM
Oct 1, 2015 01:42 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
rfourt
Sep 25, 2015 01:38 PM
atdavis2
Sep 21, 2015 01:25 PM
