Help a girl out :)
Old May 10, 2016 | 10:42 AM
X_fire_chic's Avatar
Question Help a girl out :)
Hey y'all...first post but been hiding in the shadows for a little bit. I purchased my SRT6 back in October and I have slowly been having issues with it and I could use some help to get my baby back to good running condition. I have read some other threads to identify problems and get solutions but not sure which solutions are the best. Would appreciate any help.
Symptoms:
ISSUE 1 -
a. Would misfire/lag throttle response during fast acceleration - spiratically for couple months (yes I know I should have looked into this sooner)
b. Loss of throttle at 80mph on the highway - happened once 2 weeks ago
c. Rough idle after "warm" crank - happen once last week
? Is this a misfire issue or bad coil pack? Should I replace plugs and wires?
If replacing the plugs and wires which ones do y'all recommend?
ISSUE 2 -
P0410 code
? Do I need to replace my RCM to fix this?
Thanks again for the help everyone
Old May 10, 2016 | 11:15 AM
Speedy4x4's Avatar
Default
How many miles?
What have you done to it since you purchased it?
Do you know of anything done before purchase?
Where are you from?
Might be a member close that would be willing to help, happens every once in awhile, someone knowledgeable is close.
Old May 11, 2016 | 10:10 AM
Default Re: Help a girl out :)
Originally Posted by Speedy4x4
How many miles? Roughly 55K
What have you done to it since you purchased it? nothing but an oil change
Do you know of anything done before purchase?it has needswings CAI and had the SC pulley worked on
Where are you from? I live in Houston, TX
Any idea as to what may be causing the problem?
Old May 11, 2016 | 10:23 AM
technolteacher's Avatar
I had the same problem from overfilling the oil. I am replacing plugs this weekend
Old May 16, 2016 | 02:34 PM
Hey guys,
I am still trying to solve my problems with my Xfire. Can someone offer some assistance?
BTW, I only have wifi access off and on so hence why I don't reply right away.
Thanks again
Old May 16, 2016 | 04:10 PM
tighed1's Avatar
The RCM (PO410) can be repaired (I do this). Email me:
tighed1(at)hotmail.com
Or do it yourself by following the RCM Repair link in my signature.
Old May 16, 2016 | 04:11 PM
yellowhammer's Avatar
P0410 code secondary air injection problem could be the secondary air pump ground, blue check valve on the pump or most likely the RCM has a bad relay in it. The RCM is $125 to $180 for OEM Mercedes part online.
One of the members Tigh1 rebuilds RCM's for around $25 or so. Search forum for RCM relays and you should get all the correct info on the problem.
Old May 16, 2016 | 09:05 PM
tighed1 not Tigh1 ( aka D.J. , the 2 more weeks kid )
Old May 16, 2016 | 09:20 PM
Mrmiata's Avatar
Was on BEGi website the other night.. Four Freakin years now..
Old May 17, 2016 | 12:47 PM
Thanks guys for your help with the P0410 code.
What do y'all think about the stalling and rough start up?
Old May 17, 2016 | 12:48 PM
Symptoms:
ISSUE 1 -
Old May 17, 2016 | 01:21 PM
Osofast2's Avatar
Originally Posted by X_fire_chic
Symptoms:
ISSUE 1 -
Could be the RCM that giving you most of the trouble , get that fix and see what else is going on with it , there should be a big group of Crossfire owners in TX. and I know there a lot of SRT6 owners in the state, check into Crossfire Face book , always help to have few friends close that can help you out
Old May 20, 2016 | 12:58 PM
Thanks I found the group on FB. Requested to join.
UPDATE: I changed the spark plugs, started the car ran perfect. Changed the CPS started the car ran fine. Drove 150 miles the next day no issues. THEN.....drove 1 mile to buy coffee, I get back to my car start it up and it is jumping like two rabbits going at it!
Now what? Are y'all saying that fixing the RCM will get rid of this problem?
Old May 20, 2016 | 05:11 PM
The P0410 problem will not cause this problem. Are you sure there are no other codes. The RCM can cause intermittent stop and go situations, but they do not fit your pattern, but getting the three common soldered connections resoldered would not hurt.
I am leaning toward fuel filter/fuel pump problems, the pressure regulator may be acting erratically, I'll check some more here. If I recall Valk had similar erratic behaviour.
Are the battery cables clean and tight?
Old May 21, 2016 | 01:35 PM
Thanks for the feedback. My battery cables are clean and tight. I did not see any other codes showing up on my ECU.
Do you know if changing the fuel filter is pricey or difficult to fix?
Old May 21, 2016 | 01:56 PM
Bill F's Avatar
They still have it?
Old May 24, 2016 | 11:17 AM
tighed1's Avatar
Originally Posted by Bill F
They still have it?
Yeah but only for two more weeks I heard.
So, OP did ya get the problem resolved??
Old Jun 20, 2016 | 10:03 AM
Hey guys and gals,
I am still having troubles with my Xfire. The issue is sporadic. One last week I went out to my car in the covered parking to go to lunch and when I started it up its idle was very rough. Then this weekend I was going around a corner at a light and I lost all throttle response.
Any suggestions?
Old Jun 20, 2016 | 10:10 AM
Hey guys and gals,
Any suggestions?
Over a month ago you were asked some questions, how many miles, what have you had done to the car etc. No answers yet, come on help us out here.
Old Jun 20, 2016 | 12:54 PM
SHe did answer several posts back, Dave. I'm wondering about this "SC pulley worked on".... odd.
Anyway, some of your symptoms sound like Tricia's Limited in Oakwood GA. She struggled with it, problem would come and go. Replaced the MAF twice. Found a crack in the intake box (which you don't have) - replaced intake box. Still not right, then in two weeks, it got way worse - she could not even drive it.
Just saturday, one of us here took the throttle body off and, leaving it plugged in, had her turn the key on - the throttle plate started doing a dance. Replaced the throttle body (one of us had a used spare). Problem solved and Tricia loves her car again.
But, her car has 180,000 on it. It is, I THINK the first throttle body issue I've heard of NOT COUNTING those who have done upgrades, of course. Oh, and her car threw NO codes.
(As you have been told, the P0410 code is nothing more than a distraction and emissions thing, it does NOT cause the car to run poorly.)
