Fuel Filter Issue or ?
Old Jun 22, 2018 | 03:09 PM
HPMotors1's Avatar
Default Fuel Filter Issue or ?
Anyone else ever have this problem?
Doing preventive maint on my 05 Base. 70k miles. Removed original fuel filter and installed a WIX filter which looked exactly like the one I removed except part number was different and it did not have the little mercedes star on it.
Problem. Car now takes 10-12 seconds of cranking to start. Used to start in say 2 seconds. Question - Is there any sort of check valve in the Mercedes unit? Issue seems to be fuel pressure has to build up before engine can fire. If I shut it off and wait a small while, it starts immediately. Let it sit 5 minutes or so and it reverts to the long cranking.
Is this an amazing coincidence and a fuel pressure check valve elsewhere in the system failed just when I changed the filter? Or is my WIX filter different than the Mercedes?
BTW, I am a long time forum member but was unable to log on and had to create a new User Name as I hope to hear back from someone
HP
Old Jun 22, 2018 | 03:17 PM
Default Re: Fuel Filter Issue or ?
Yes, the OEM filters contain a check valve.
Old Jun 22, 2018 | 03:19 PM
Another reason I buy most of my stuff from Rob at Needswings - I cna't stand fooling with issues like this.
It could be a coincidence - you can prove what is going on by measuring fuel pressure at the end of the rail towards the front of the engine. THere are kits you cna buy to easily measure the pressure - you should see something over 40 pounds. (I THNIK the spec is 50-55, but Dave (100/80) will chime in when he sees this......)
Old Jun 22, 2018 | 03:22 PM
You can also determine if this is the issue by turning ignition on, listen till pump stops, turn ignition off, then on again.
Do this about 3 times before you actually go to 'start'
If it fires right up, pressure was the issue.
( and the spec is 52 - 60 PSI - Dave's napping, them old geezers do that this time of day )
Old Jun 22, 2018 | 03:26 PM
(Dave's napping, them old geezers do that this time of day )
He isn't older than YOU is he? I mean, is ANYONE?
Old Jun 22, 2018 | 03:33 PM
Not many. Dave and Carl come to mind of people I am familiar with, although Dave and I have actually never met.
Old Jun 22, 2018 | 05:18 PM
HPMotors1's Avatar
Hey all - BIG thanks for the quick responses! I had looked under FAQ, known issues etc but did not see the answer there - course I'm half blind in one eye and can 't see out the other. We have a garage with lots of tools but Crossfire is a personal car and we don't have an adapter to fit the Merc engine fuel port - guess I will have to buy one! Cycling the key on and off did the trick.
Already went to town and bought a store brand Mercedes Benz filter - identical part number to original. Only difference is the first one in the car was made in Austria, the new one is made in Germany. Cost twice as much as the Wix thing but hey!
thanks again.
Henry
Old Jun 23, 2018 | 12:12 AM
lllouj1's Avatar
You probably replaced the original clamps with the screw type clamps. The screw type clamps cannot hold the pressure and air is leaking past them causing the long start. Once you replace the clamps with the crimp style, I am sure that your long start problem will go away
Old Jun 23, 2018 | 01:18 AM
dinasrt's Avatar
Why is there air? And I have to question this post.
Old Jun 23, 2018 | 07:15 AM
lllouj1's Avatar
Question all you want. A new filter will do the exact same thing as long as you use the wrong clamps. You have to replace the clamps and use the crimp type clamps that was originally on the hoses. Until then, air will keep leaking past the clamps causing long starts. You can try tightening your clamps but they will eventually leak again until you replace them with a crimp style.
Old Jun 23, 2018 | 08:05 AM
I replaced my filter in 2011 and used screw type clamps. Not a single slow start or any other problem since.
Old Jun 23, 2018 | 09:05 AM
Steve Jr's Avatar
What a weird thing to say. I believe we've all used screw clamps , on every vehicle we've owned. But , you cant use a 2" clamp on a 5/16" line and expect it to work....
Old Jun 23, 2018 | 09:08 AM
Can you explain why a gap that allows the air to leak into a hose does not leak from that gap with a back pressure of 50 psi on two ports?
With no pressure in the hoses gasoline should leak from that gap, air would not leak in though.
I agree that the crimp style clamps are preferable to the screw type clamp on the small diameters.
Old Jun 23, 2018 | 10:27 AM
turbomar's Avatar
Do you work for CNN? That sounds like fake tech tips! Lol
Old Jun 23, 2018 | 10:43 AM
A set of these might not be a bad idea, haven't tried them on our fuel lines myself, but think I might.
Stainless Steel, and they will maintain pressure unlike the screw type clamps :
https://www.denniskirk.com/drag-spec...335117#reviews
Old Jun 23, 2018 | 10:59 AM
But can they hold that 50 + psi over time, I would hate to find that they fail miles from anywhere.
Old Jun 23, 2018 | 11:07 AM
Good point.
Old Jun 23, 2018 | 01:23 PM
lllouj1's Avatar
Try tightening up the screw clamps to prove my point of an air leak. It should work for a day or two and this will prove my point. Then you need to replace with crimp type. Then we will see whose right or wrong!
Old Jun 23, 2018 | 05:20 PM
The hoses are not a loose fit on the filter so even without a clamp they would not leak air, they would of course come loose with pressure in the hose. If the pressure drops in the system very quickly then the regulator in the filter has failed, it is a fairly common problem which you would know if you did a search on the subject. Replacing the filter with one 5hst does not have the regulator in it will mimic the filter with the totally failed regulator.
You need to tell us how an air leak does not result in gasoline leaking through the same gap.
Old Jun 23, 2018 | 05:32 PM
thanks again.
Henry
Let us know if this works out.
