ESB BAS and NO Super Charger
Old Jun 23, 2018 | 08:44 PM
Joef89's Avatar
Default ESB BAS and NO Super Charger
So have a 2005 srt6 roadster. It has a ecu tune, Dual Cold Air, Coolant isolation kit, and a catch can. So when we bough the car we had to drive it down form ohio where we got it to florida where we live. On the drive down we noticed the super charger had cut out. when we got back to florida we replaced the IC pump as we thought this was the issue. in addition to that we noticed that there was a wobble in the water pump bearing so we replaced that. at this same time we did the IC always on mod. Today when driving we again lost the supercharger, btu we noticed that the ESB bas light had come on. As we thought about it the esb . bas light would always com on when we would loose the SC.
Anyone have any ideas what could be causing this and how we can get it fixed.
Old Jun 24, 2018 | 10:16 AM
Default Re: ESB BAS and NO Super Charger
Turn both taps on the bypass kit to integrate both circuits and see if the SC works and see if the level of the coolant in the overflow tank has dropped noticeably. If this is so then I would say the inter-cooler is leaking.
I cannot see a connection to the light though if the above is the case.
I wonder if a brake switch or MC pressure switch failure would make the car switch off the SC as if there was a total brake failure. Check the car for any fault codes set.
Old Jul 2, 2018 | 10:46 PM
Joef89's Avatar
SO tested the IC isn't leaking. Still havent figured it out. checked the wheel speed sensors as someone had said that maybe it was corrosion on the plugs, swapped out the RCM, but no luck.really cant figure out what it may be.
Old Jul 3, 2018 | 08:08 PM
Sussudio's Avatar
Is the supercharger clutch engaging? If not check the spacing of the shims as if it’s too far apart that could be causing it to cut out.
Old Jul 4, 2018 | 07:07 AM
KDW4Him's Avatar
How firm is the brake pedal? A pressure difference in the system should give only a BAS light.
BAS and ESP lights or just BAS? BAS/ESP will default the car to a safe mode. NA's will have the spoiler stuck up so I would guess the computer won't let you use the supercharger if you don't have traction control. (ESP) Mine was a speed sensor and the BAC controller.
Good advice to leave the valves open in the isolation system until this gets resolved.
You have a volt ohm meter? You can test each wheel sensor.
pahkcah02
Nov 23, 2012 12:02 PM
Stogey
Jun 21, 2008 06:28 AM
Rokypoky
Apr 21, 2008 07:26 PM
Montana Crossfire
Apr 19, 2008 07:17 PM
04Roadster
75
Oct 11, 2006 07:47 PM
