High Beams
Old Jul 6, 2018 | 11:34 AM
DHS's Avatar
DHS
Exclamation High Beams
So this mourning my high beams would not work, lows and blinkers work but no flash or highs! Looked at the fuse list and it does not show one for the lights! I don’t think both went bad at the same time, anyone seen this?
Thanks
Dan
Old Jul 6, 2018 | 02:16 PM
Default Re: High Beams
Fuses 3 (right) and 5 (left) are the high beams (in the ICM panel, left end of dash).
But it sounds like another "Multifunction switch" failure. I hope you find that both fuses are blown or that both lamps are burnt out. (But you and I both know that is not likely.)
Old Jul 6, 2018 | 02:20 PM
You looked at the wrong list.
Fuses 3 and 5 in the ICM fuse panel (left end of dash, open car's door to access it) are the separate right and left high beam fuses. I hope your fuses or bulbs are both bad, because it sounds like your multi-function switch (the stalk/switch assembly) is the cause - and while not super expensive to buy, replacing it is apparently a bit complicated.
Old Jul 6, 2018 | 06:21 PM
DHS's Avatar
DHS
Unhappy Re: High Beams
At $450 and I have to take the dash apart, it will be a long weekend!
Old Jul 12, 2018 | 12:52 AM
Thanks
Dan
Is it possible that the main light switch has a loose plug on it or it is at fault somehow.
I think and you could check this but the multifunction switch high beam flash and high beam work through the light switch itself
If t is the MFS then eBay has them used for much less than $450.
rmcdaniel12
Nov 1, 2014 03:38 PM
brewski
Jan 16, 2010 03:59 AM
TX_xfire
Aug 21, 2009 03:15 PM
dkriegh
Jun 11, 2008 11:56 AM
dkriegh
May 19, 2008 04:45 AM
