Lights in rocker panels
Old Oct 21, 2018 | 02:17 PM
Default Lights in rocker panels
Does anyone know if there is room behind the rocker panels to put an LED light such as the license plate light under the doors that light up when you unlock the door, coming on with the interior lights? A neat feature I think when used at night.
They would come on when you unlocked the doors, opened the doors from inside etc. They would need to be pretty thin, I think you could thin the license plate lights by modifying the terminals.
Old Oct 21, 2018 | 04:38 PM
bluecoupe's Avatar
Default Re: Lights in rocker panels
Dave, if the LED LP lights won't fit, you could put a strip of LED lights on the outside surface of the trim panel, there's a linear indentation where the fasteners are. I think an LED strip would be thin enough to go under the door as well.
Old Oct 21, 2018 | 06:06 PM
Larry Hitze's Avatar
That is a really neat idea Dave!
Old Oct 21, 2018 | 06:18 PM
I have some about 6” long x 3/4” wide that say they are 100% waterproof and stick on with 3M double sided tape, maybe they might do with a bit more waterproofing.. I had forgot I had them till you mentioned them.
Old Oct 22, 2018 | 10:16 AM
Toolman's Avatar
A trick to find the gap between doors and door jams, or air cleaner box and hood, is to use Silly Putty on one surface with the other side of the putty covered with plastic wrap. Shut the door or hood and it will squash the putty to the thickness of the gap. The plastic wrap stops the putty from sticking on the surface on that side.
Old Oct 22, 2018 | 10:32 AM
I may have to do it this way, I have had the rockers off before to clean them and broke some of the clips, so I had better get some of them before I attempt it.
I prefer the license plate light as I think the stick on ones are a bit tacky.��
Old Oct 23, 2018 | 05:55 PM
Let us know how it turns out.
Old Oct 23, 2018 | 06:11 PM
I would mount them on the bottom of the door jams. Mounted on the rockers, too much crap from the road will get on them, not to mention driving water from the front wheels when it is raining.
Old Oct 23, 2018 | 07:22 PM
That is a fair option but I would like to see the puddle when I unlock the door not open it and find I am standing in one.
Old Oct 25, 2018 | 12:07 AM
I'm with you, just as soon they came on before I got there and lit up underneath.
Old Nov 2, 2018 | 11:30 AM
BadSRT2005's Avatar
My taurus has puddle lights mounted on the underside of the side view mirrors, so thats an option!
Old Nov 2, 2018 | 12:21 PM
My buddy has them on his Land Rover, it projects the words ‘Range Rover’. I do not think I’ll go that far, that must be a cool $1,000 on the car price.
Old Nov 2, 2018 | 03:17 PM
bluecoupe's Avatar
I have them for the GLK, they simply replace the OEM ones in the doors.
https://www.ebay.ca/itm/2-PCS-Door-L...7:pf:0&vxp=mtr
Old Nov 4, 2018 | 03:03 PM
Ajbarbier's Avatar
Does anyone know how to wire this all up?
Old Nov 4, 2018 | 03:50 PM
I mean the whole package must add a thou to the MRP, cameras on all four sides etc. Service is a very expensive item. Guess I’ll stick with the wife’s Hyundai.
Old Nov 4, 2018 | 05:29 PM
Run wires from inside the car connected to a circuit that becomes live with the doors open, as shown here, CLICK. Then run the wire forward under the carpet and come up and over the sill where it is covered by the sill cap which has CROSSFIRE embossed on it. Run it along the side of the sill and put the wires through the gap at the forward edge of the rocker cover.
There may be better ways to run the wires upon more thought.
After all how hard could it be?
T. K. D.
Mar 25, 2016 06:32 PM
xfire92
May 3, 2012 01:42 AM
James1549
Jul 2, 2008 06:39 PM
James1549
Jun 27, 2008 08:50 PM
rabbitroodle
Aug 26, 2004 07:55 AM
