I finally changed my plugs after 203,000 miles.
Old Nov 26, 2018 | 08:27 PM
8ighth Wonder's Avatar
Default I finally changed my plugs after 203,000 miles.
I got a hold of some bad gas. It was the color of green Gatorade and had water in it. I disconnected the fuel line where it goes into the rail and used the relay to activate the pump. This actually went pretty quickly. I was averaging 23-26 mpg prior to the change, with the occasional stumble here and there. I wouldn't recommend anyone do this but I was curious as to how long the plugs would last.
Old Nov 27, 2018 | 01:30 PM
Toolman's Avatar
Default Re: I finally changed my plugs after 203,000 miles.
They look better than I would expect for that kind of mileage. Any trouble removing them?
Old Nov 27, 2018 | 04:52 PM
The angle was a pain, so I used a combination of different swivels and a gimbal ratchet. A 24" 3/8 extension also helped prevent me from having to bend over. #6a was the biggest PITA because of the heat shield being so close. But they pretty much came right out. They were a little tight but not too bad.
Old Nov 27, 2018 | 05:19 PM
15Spokes's Avatar
What did you use to get the boots off? Did you use the recommended 17mm, dog leg MB spanner?
With our leads starting to get a bit old now I am reluctant to just pull them off by hand in case I damage them.
Old Nov 29, 2018 | 02:59 PM
waldig's Avatar
You twist them off. Woody
chevy_67_327
Apr 9, 2018 09:12 PM
austinboyette
Dec 3, 2017 04:42 PM
windsorxfire
Mar 29, 2009 06:58 PM
sharptech
Nov 5, 2007 01:57 PM
cfire520
Feb 7, 2007 02:52 PM
