Fog Lights Just Quit Working
Old Jan 18, 2019 | 07:55 PM
ekline49's Avatar
Default Fog Lights Just Quit Working
Hello All --- can anyone shed any light on why my fog lights quit working? They worked fine until recently. The switch seems fine and all other switch functions work fine. Could they both have blown at the same time? They look ok. Any ideas would be genuinely appreciated.
Old Jan 18, 2019 | 08:29 PM
bluecoupe's Avatar
Default Re: Fog Lights Just Quit Working
Check your trunk for water
https://www.crossfireforum.org/forum...-turn-off.html
Old Jan 18, 2019 | 10:59 PM
The ICM has control over them, remember, when you hit the high beams, the Fog Lights are turned off. Check fuse nine in the ICM, if it is good, replace both bubs (or "check" them).
If that does not do it, you may need either a new ICM or new multifunctino switch
Old Jan 18, 2019 | 11:01 PM
If she service manual diagrams are accurate (big IF), the CLP/SSM can make the fog lights stay on, but cant keep them from coming on.
Old Jan 19, 2019 | 12:54 PM
Check the fuse and if it is OK check for power at the fuse upstream terminal if the fuse is OK it will tell you which side of the fused wire has the problem, no power at the fuse then the trouble lies upstream of the fuse. Power at the fuse means the trouble lies downstream.
eruby
Jan 5, 2016 05:14 PM
meh03
Apr 22, 2014 06:24 PM
Louie K
Aug 29, 2009 12:03 PM
TX_xfire
Aug 21, 2009 03:15 PM
chocoholic_too
Sep 18, 2005 10:43 PM
