Oil level sensor leakage after oring replacement
Old May 27, 2020 | 05:52 PM
nelro_PL's Avatar
Default Oil level sensor leakage after oring replacement
Hi guys,
In the beginning sorry if the topic was in the past, but my English is not very well and i coudn't find answer for my problem.
I have just replaced the oil sensor oring, and after finished job I started engine and... leakage appeared again;./ Is it possible that the sensor is damaged inside and making oil leakage?
BR
WOjtek
Old Mar 22, 2026 | 07:46 PM
HumanMode's Avatar
Default Re: Oil level sensor leakage after oring replacement
Hi there - I've got a similar leaking problem on a working sensor did you end up replacing the o-ring, or the whole unit?
Old Mar 22, 2026 | 09:53 PM
steve1189's Avatar
From personal experience, my sensor was leaking and a mb mechanic I know advised me, and gave me a Merc o-ring He suggested to replace it and it should fix the leak. It still leaked after replacing it. Ended up replacing the sensor and all is good. Sensor was leaking through the top. Good news is, I'm pretty good at re and re sensor since I did it twice.
Old Mar 23, 2026 | 12:44 AM
You should replace the whole unit with a new sensor.
Here's my post from when I replaced mine:
Oil Level sensor replacement
HumanMode
Mar 22, 2026 05:32 PM
DeKalb
Jun 14, 2022 06:05 PM
DeKalb
Jun 14, 2022 12:40 PM
Mtnears
Nov 26, 2019 02:32 AM
Hayabusa1300
May 12, 2011 06:54 PM
