Wiring conundrum
Old Aug 10, 2021 | 11:11 PM
Mr. Max's Avatar
Default Wiring conundrum
To make a long story short, the rats ate the wires under the driver-side fuse box and I'm soldering them back together. My problem is that there are two identical light green, no stipes wires. Using a river analogy. On one side of the river are 2 greens, one with voltage and one with no voltage (hot and not) on the other side of the river, I have the same situation, 2 greens, "hot" and "not". My thinking would be the "hot" wire on the north side of the river would go to the "not" wire on the south side of the river and the "hot" wire on the south side of the river would go to the "not" hot wire on the north side of the river. HELP!
Old Aug 10, 2021 | 11:43 PM
Default Re: Wiring conundrum
Originally Posted by Mr. Max
To make a long story short, the rats ate the wires under the driver-side fuse box and I'm soldering them back together. My problem is that there are two identical light green, no stipes wires. Using a river analogy. On one side of the river are 2 greens, one with voltage and one with no voltage (hot and not) on the other side of the river, I have the same situation, 2 greens, "hot" and "not". My thinking would be the "hot" wire on the north side of the river would go to the "not" wire on the south side of the river and the "hot" wire on the south side of the river would go to the "not" wire on the north side of the river. HELP!
Sometimes these small wires have barely noticeable coloured lines down them, visible at some points down the wire and not at others. I cannot see two green wires side by side.
Have you found the schematic of the fuse box?
Old Aug 11, 2021 | 05:38 AM
Mr. Max's Avatar
Thanks, OneHundred80, I can't see any difference on the wires. There might be one somewhere down the line but it is pretty hard to get "down the line." That Rat Bastard picked the worst possible place to sharpen his teeth. I've poured over the schematics to no avail. I think I'm pretty safe comparing the length of the wires, long on one side of the break to short on the other side of the break and vice versa. The rat would have had to take a section out for that not to work. However, I thought I CYA and throw it out to you all before I proceeded with wire surgery. Thanks again, Max
Old Aug 11, 2021 | 06:46 AM
waldig's Avatar
Just make a choice. but do so with a small in line fuse like 1 amp or so and see what happens. At least you can get a feel for the hookup and fusing BOTH leads will afford some protection. Woody Enjoy.
Old Aug 11, 2021 | 11:38 AM
The size of the wire (gauge) would be an indicator of the current designed to pass through the circuit. Putting a 1 amp fuse there if the circuit is designed for higher may lead you astray as it may blow due to its normal current flow. Your comment " I think I'm pretty safe comparing the length of the wires, long on one side of the break to short on the other side of the break and vice versa. " makes a lot of sense seeing as a harness assembled seems to follow that logic (unless they are normally exposed and jumbled where that damn bastard rat went to sharpen teeth). Leaving them disconnected and finishing the splice, then seeing if the car works/runs, would then let you know what circuit(s) to look up for the color codes your seeing. Two suggestions offered, your choice to consider. Good luck!
Old Aug 11, 2021 | 12:40 PM
Toolman's Avatar
First off I'm very sorry to hear about that happening.
There are actually two fuse box panels on the driver side. You have the fuses accessed through the side of the dash on the driver side. That is part of the Illumination Control Module. Looking at the 2007 service manual the wiring pin outs, color codes, and purpose is on pages 8W-080-35/36. I didn't see any light green listed.
The second fuse block which is under the hood on the driver side is the Underhood Accessory fuse block. The fuse list, wire colors, and funtion are on pages 8w-10-3. I didn't see light green only wires listed here either.
There are located there as well.
Old Aug 11, 2021 | 01:07 PM
Toolman's Avatar
I happen to have a used spare Illumination Module with pig tails. I pulled it out to check the wire colors. It has three light green wires with white strips and a single light green wire with no color strip. The all green wire is listed in the Illumination Control Module B connector pin out diagram (provided above). It's # 14 pin connector with a wire color of DG which stands for Dark Green. It certainly looks light green to me. It's function is Fused Illumination Control Module Output. LG would be for Light Green. There are no other green wire color codes in the wire color code chart.
Old Aug 11, 2021 | 02:20 PM
Doc78's Avatar
I have to say the effort that people like Toolman put into this forum makes it great place. Thank you Toolman!
Old Aug 11, 2021 | 08:12 PM
Mr. Max's Avatar
Great idea, Woody, Thanks! Jeff
Old Aug 11, 2021 | 08:18 PM
Mr. Max's Avatar
Smile Re: Wiring conundrum
WOW! Talk about an "above and beyond the call of duty" answer. I didn't expect such a fantastic reply. Thank you, Toolman, Jeff (Mr. MAX)
kamilspider
Apr 16, 2020 11:44 AM
tylerxfire
Jul 3, 2015 05:32 PM
antwaun42
Sep 5, 2014 04:19 AM
bmorgan
Mar 29, 2010 10:15 AM
XFire Woodie
Jul 1, 2007 11:58 PM
