Engine shut down
Old May 15, 2022 | 06:16 AM
cobra1951f's Avatar
Question Engine shut down
Good morning: i have a 07 crossfire convertible driving and engine just shut down!! No sputter nothing!! Turns over but won’t start?? Any and all suggestions!! Was running fine till it shut down!!
Old May 15, 2022 | 08:43 AM
DTMenace's Avatar
Default Re: Engine shut down
cobra1951f
You asked the same question yesterday (see link below) and received a correct answer that it is a RCM issue discussed on this forum many times in the past. There is no need to continue to add additional threads related to your NO START scenario.
Just click on the link below, your answer is awaiting you....
Dennis
DTMenace
What did you do to your Crossfire today? - Page 374 - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
Old May 15, 2022 | 10:30 AM
Either the fuel pump relay on the RCM is bad or the Crank Position Sensor is bad.
THIS IS NOT THE MYSTERY NO START, because the starter is engaging.
If it starts when cooled off, I vote for Crank Sensor.
Old May 15, 2022 | 10:32 AM
I wouldn't rule out a bad Crankshaft Position Sensor. James
Old May 15, 2022 | 02:50 PM
cobra1951f's Avatar
It did not start up after sitting over night and you can hear the fuel relay clicking and it turns over but doesn’t even ty to start so i will try to pick up a crank sensor and try that?? Thanks
Old May 15, 2022 | 08:43 PM
You aren't getting spark OR you aren't getting fuel. There have been reports of complete failure of fuel pumps but there are also reports (TONS OF THEM) of Crank sensors going south.
I invested in a $40 fuel pressure test kit a few years ago, sure takes the guesswork out of this -and it's as easy as checking tire pressure.
I bought this one at Summit:
https://www.summitracing.com/parts/otc-5630
phil alvirez
17
May 16, 2022 10:33 PM
johnslowley
Jun 26, 2017 03:48 PM
Uk Pete
U.K.
23
Mar 22, 2013 03:31 PM
jscupa
Nov 20, 2008 08:04 AM
dkomeshak
Jan 3, 2004 06:53 PM
