Engine won't turn over - ECM P0410 & P0335
Old May 23, 2022 | 09:00 PM
RUBRDUX's Avatar
Default Engine won't turn over - ECM P0410 & P0335
About 3 weeks ago on my way home from work in stop-and-go traffic my car died. It still had full electric capabilities; the engine just quit. So I threw it in park and restarted it w/ no issue. I drove on home briefly thinking to myself, "That's gonna be a problem someday."..
A few days ago it happened for the second time, almost in the exact same spot on the interstate, while going home in stop-and-go traffic. My car, as before, still had full electric capabilities; the engine just quit. But this time it wouldn't turn back over. It would crank. If I turn the key all the way to the right it would keep cranking for about 8-10 times (even after I stop twisting the key) but it would not turn over. So I had it towed back to work. (I work at a bodyshop)
With my technical/mechanical ignorance I used a scanner and decided to replace the Crankshaft Position Sensor. It would start but eventually die if left idling & immediately die at about 4000rpms if I gave it gas. I cleared the codes, started it again and it sounded and ran more smooth than I've ever felt it!! (I bought it at around 45,000 miles, it now has 88,000.)
After driving it around the parking lot I decided to try to take it home. I only got about 2 blocks away before it died and wouldn't turn over again.
So, now I'm not sure what to do.
I scanned it again and attached the printout for you to view.
(See attachment)
I've seen threads about similar problems here, but they are old and don't make sense to me.
So I'm just starting this thread, from scratch, regarding my issues. Sorry if I'm beating a dead horse.
Thank you for taking the time to read and even more thanks if you respond with your wisdom/experience.
Old May 23, 2022 | 09:02 PM
Ronman's Avatar
Default Re: Engine won't turn over - ECM P0410 & P0335
(See attachment)
The P0410 code is almost always the RCM. Did you change the crankshaft position sensor with a genuine Bosch one?
Old May 23, 2022 | 09:34 PM
RUBRDUX's Avatar
No. I just used whatever O'reilly Auto Parts sent me = An "Import Direct 2 terminal crankshaft position sensor, Pt# 19-0462". *shrug*
Should I get a Bosch one and try that before doing anything else? What would you advise my next step be?
Old May 23, 2022 | 09:42 PM
Ronman's Avatar
For sure change the crankshaft position sensor to a genuine Bosch one. I checked the reviews on the part number you gave me and they were not good. After that you most likely need to change the RCM, there is a member here that repairs them. You can send it to him first or buy a new one then send him the old one.
Old May 24, 2022 | 12:05 AM
No wonder the car is mad at you, I'd be pissed too. Go buy the RIGHT part. German Auto Supply has them, as do other places - search "Mercedes SLK320 Crank Positoin Sensor" and buy ONLY the BOSCH part. If you search for the Crossfire, you will never get the car running.
Here, I did all the work for you: You want the BOSCH at the bottom of the page:
https://www.germanautosupply.com/cat...nkshaft.Sensor
The P0410 is nothing to worry about, get the car running and deal with that later. As you have been told, you can send the RCM to DJ and he can fix that 410 thing for you for around $60.
You can buy them on eBay for around $75 used that might work, or a new one at PartsGeek for $240 - but what ever you do, send your bad one to DJ for rework and keep it in the trunk for next time.
Old May 24, 2022 | 11:49 AM
tighed1's Avatar
RUBRDUX Agree with the gotta be a BOSCH CPS comments.
If interested in getting your RCM refurbished email tighed1@hotmail.com for the details. That should clear up the P0410 fault.
Dave may chime in and tell you that it could also be the blue check valve or air pump motor, but we all know it's usually that the relay contacts on the air pump relay are burnt that causes the P0410.
Old May 24, 2022 | 07:27 PM
RUBRDUX's Avatar
Thanks for all the help guys!!
This is the one you suggested I get.
(See the cross reference part number circled.)
But I got this one instead.
Aaaaand this is what happened...
Spoiler
Old May 24, 2022 | 11:57 PM
New ones can be had for $150 or so, just search this forum they have been mentioned a lot of times, I forget the brand name.
Old Mar 16, 2023 | 09:13 PM
Romad's Avatar
UPDATE 3/16/23: Been five days since I changed the camshaft and crankshaft sensors and not stalled and has been working just fine "so far!" Ordered Bosch sensors and will swap the aftermarket ones, I installed on 3/12/23, with the Bosch sensors.
Old Mar 17, 2023 | 11:33 AM
Very wise. The aftermarket sensors have wasted a lot of owner's time and money when they change to them, and then, weeks later, the car does odd stuff. AT that point, it is assumed the issues is something else, but its the new sensor(s). I don['t know what it is about the BOSCH part, must be manufacturing tolerance or something, but other brands SOMETIMES work fine, but often, they do goofy stuff.
Vipor3D
Feb 2, 2021 07:58 PM
jtaylortech3
18
Nov 27, 2015 09:00 AM
saranomie
Sep 5, 2014 12:44 PM
Louie K
20
Jul 14, 2011 11:27 AM
Bob_Ham
May 19, 2010 12:11 AM
