AirBag Sensor Module - Airbag Failure Light
Old Oct 10, 2022 | 02:35 PM
jvicain50's Avatar
Default AirBag Sensor Module - Airbag Failure Light
MODERATOR NOTE: SEE POST 16 Do not miss the discussions that follow, either.
I'm looking for airbag sensor module (68024494AA / A1938200526) for 2008 Chrysler Crossfire Roadster.
OR does someone that can repair the unit
Thks, James
Old Oct 10, 2022 | 04:27 PM
Default re: AirBag Sensor Module - Airbag Failure Light
Thks, James
What’s wrong?
Old Oct 11, 2022 | 10:34 AM
jvicain50's Avatar
My airbag light is on all the time.
Old Oct 11, 2022 | 01:36 PM
That proves one thing, the bulb is good.
Old Oct 11, 2022 | 02:36 PM
Ronman's Avatar
Thks, James
There are sites online that say they can reset it. Yours is the Crossfire specific version, 04 and 05 had the Mercedes version which is compatible. On Car-part.com an auto salvage place said they had one in stock referenced with the Chrysler part number (68024494AA), the phone number is 817-330-0040 I would make sure the airbags were not deployed and if they can send you a picture of the actual part so you can confirm the part numbers.
Old Oct 11, 2022 | 04:42 PM
And be sure the battery is disconnected if you mess with it.
Old Nov 7, 2022 | 05:51 PM
EnsoniqDude's Avatar
Mine just popped on today. 32K miles. 2007 Roadster.
Old Feb 12, 2023 | 02:53 PM
kas's Avatar
kas
Having the same problem with my 2007 @ 15,000 miles. Any solutions out there?
Old Feb 12, 2023 | 03:15 PM
Padgett's Avatar
BTW the '07 and '08 airbag was the subject of a recall and they never expire.
Old Feb 12, 2023 | 04:16 PM
kas's Avatar
kas
The airbag part recalled was replaced. Not the problem. The problem is replacing a module no longer available.
Old Feb 12, 2023 | 05:06 PM
Padgett's Avatar
Then I would be tempted to "fix" the light. Does it impact performance ?
Why for cars 20ish years old, I tend to have a spare. Also provides a shed for the parts.
Old Feb 14, 2023 | 10:57 AM
kas's Avatar
kas
This problem seems to be hitting the 07 & 08s lately. Not the same module as 04-06s. Let me know if you find a solution.
Old Feb 14, 2023 | 12:15 PM
I have a solution: Get over it. Just because the nanny state says you need an airbag, does NOT mean you need an airbag.
My light has been on since 2016 in my 07 SE. I got a new module, but as others have learned, the 07-08s take a different module.
I gave up. I'ts just a harmless little light. I've had two instances of airbags going off in my face, in both cases, the only injury from the accident was caused by the airbag.
I'd be better off removing the steering wheel airbag anyway.
Old Mar 20, 2023 | 02:29 PM
Ms Kitty NJ's Avatar
I have an 08 Crossfire Ltd coupe.
Looking for any info if the ORC module in the MB SLK R170 platform can be used to replace the ORC module no longer supported/produced by Chrysler with regards to the SRS system and air bag light on?
I did the unthinkable and went to dealer who has a Crossfire experienced tech and tools to diagnose the vehicle. My light came on back in Sept. 2021 thought is was because the battery went dead in vehicle. Not the problem the ORC module went bad. The Chrysler tech traced out all the wiring and found it to be in working order just bad ORC module.
Can the ORC module be repaired or must it be replaced.
Appreciate any info on this subject. For now a piece of electrical tape takes care of having see the light!
Thank you Miss Kitty NJ
Old Mar 20, 2023 | 02:38 PM
kas's Avatar
kas
I have the same problem. 2007-08 Crossfires apparently have passenger airbag modules unique to those 2 years. Due to the fact few 07-08 CFs were produced and the modules are no longer manufactured we have to wait for a rare one to come available as a used part. That's the information I've come up with. As for "repair", I've been given different information. No one has stepped forward to tell of a successful module repair.
Old Mar 20, 2023 | 02:57 PM
FIRST:
Just do what I did: FORGET IT. The airbag injures a lot of people and saves only one person out of 250,000 crashes anyway.
YOu can take a used one form another car PROVIDED it matches your year (due to the changes made that post 15 addressed, the 07-08s used a different module, keep reading) and, using a STAR computer or similar, reset the used module to your car. You can not order new ones for Crossfires or MB products, this is not a "Crossfire" failing, it's because the platform is not supported very well even by MB.
The 001 820 08 26[08] is used in a TON of MB products, but you can't get them anymore.
SECOND:
The only repair facility I of is these people and they dont do/no longer do Airbag modules:
http://www.sosdiagnostics.com/
THIRD:
Detailed answer from Clint, retired Chrysler engineer for safety systems (and proud Crossfire owner, he comes to Woodward, the Dragon, etc.) on the Crossfire and other Chrysler products in the 1990s and 2000s:
The airbag module had to be different for 2007-8 because the knee airbag was added. At minimum that would have required software updates, which would have (should have) been indicated by part number differences, too. But the whole Crossfire part number strategy and control was complicated by the Chrysler & Karmann & Mercedes mix of parts and control.
In some (normal) Chrysler modules the module part number could sometimes stay the same, but firmware could differ according to vehicle equipment or trim level. Sometimes this firmware could be changed or updated by dealership equipment. The bastard status of Crossfire DRB III dealership diagnostic makes me expect this is NOT possible for a Crossfire.
TL;DR short answer: No, airbag module must be different. Oh, and the idea that the module would ever have been the same as in R170 would not be true. Even if the connected airbag hardware was the same, crash calibrations would have to be different for the different cars.
Old Mar 20, 2023 | 03:05 PM
kas's Avatar
kas
The state of Rhode Island allows NO dash lights to be on at the time of safety inspection in order to receive the state required inspection sticker. NO lights on. Much less the bright red airbag light.
Old Mar 20, 2023 | 03:11 PM
Yea, and soon, all states will require the car to be electric and what that will cost you is not their problem, but yours.
We have emissions and "Safety" inspections in Texas. I was nervous as my light has been on five years and I just moved here. Guy said, "That light is not on my safety list, so you are good". They look at outside lights, turn signals, emergency and regular brake operation, wipers, tire tread depth and if the windshield washer works - that's it.
You know, you can disable the airbag light. If they are not scanning specifically for that item, I believe you'd be fine. If you want help with that, I can send you instructions.
Old Mar 20, 2023 | 03:17 PM
Padgett's Avatar
BTW a good scan tool will tell both the manufacturer and usually the part number of the module. Unfortunately mine is an 04 and different however previously I had an '07 and the recall was done. It was a nightmare.
For NLA parts I usually go to eBay but SRS light (caused by the ORC) could be caused by an improper battery change.
kas's Avatar
kas
Thanks, but I don't have the savvy to do it & finding a mechanic here willing to risk their state license to do it will be difficult. I've asked a few.
