rear wheel sensors axle swap differential
Old Sep 16, 2023 | 03:56 PM
cross2's Avatar
Default rear wheel sensors axle swap differential
hello everyone I doing a differential swap on my 2005 NA , I adapted a super 8.8 differential and custom axles from DSS , the axles could not adapt the abs rings ! this is where i need some help? could the rear wheel sensors be wired to the front wheel sensors to fool the abs controler ? if so has anyone done this ? any ideas ? need help
Old Sep 16, 2023 | 08:46 PM
Default Re: rear wheel sensors axle swap differential
I'd like to see if that would work. Try it.
1) At the CAB connector, within a foot of the connector, splice the wires to the front left wheel with the wires to the rear left wheel.
2) At the CAB connector, do the same with the wires to the front right and rear right.
3) DO NOT leave the wires running to the rear wheel connectors connected, disconnect them at C201 as shown.
I am pretty sure this is a profoundly bad idea, but I would like to see if it works. The screen shot below is fuzzy, download the service manual and go to the page indicated, you will get it.
This can't possibly work, but try it.
MANUALS ARE HERE:
https://www.crossfireforum.org/forum...ollection.html
Old Sep 27, 2023 | 10:21 AM
nemiro's Avatar
I just finished putting a HAG215 in the car, and I thought THAT was a difficult project. I've had DSS axles in multiple vehicles. I am surprised that they could not adapt it. As for the ABS sensors, I cannot imagine that you will get the ESP to play nice splicing the signal wires in. It might work, but I sincerely doubt it. The ESP is one of the "smarter" modules in the car, and being safety related, it will trip a fault code over the most minor issue. As Mark said, if you do it, make sure to unplug the rear sensors.
Separately, please do post up pics of this swap. This kind of mixing of parts and fabrication is right up my alley, so I'd like to see how you approached it. Thanks!
Old Sep 28, 2023 | 09:05 PM
cross2's Avatar
sorry for the long response time at this point i have differential cradle fabricated and differential fitted nicely one piece driveshaft - had to use the charger=300 rwd 110mm companion yoke on transmission crossfire is 100mm it was a direct bolt on . the comaro- GTO uses the same 110mm 3 bolt flange and same pilot shaft size- adapter to U-joint again bolt on differential was out of 2121 S550 mustang 3:55 LSD 3000 mi it also used adapter to u-joint bolt on then had 3" drive shaft with slip joint made joint to joint CL 40" / Im still in the process with DDS ABS rings or not ? bill
Old Sep 28, 2023 | 09:23 PM
nemiro's Avatar
I'd have to go back and look, but I think there are 40 notches in the CF tone wheel. As long as you can get close to that, adjustments in the computer for tire sizes will likely be the way to go to fudge it to get it to read right.
Old Sep 30, 2023 | 02:07 PM
cross2's Avatar
Nemiro yes its 40 notch . The 40 from my post was driveshaft 40" U-joint centerline to U-Joint centerline. Question when DDS did your axles did they bore and respline your wheel hubs ?
Old Sep 30, 2023 | 02:22 PM
nemiro's Avatar
DSS did not do the ones on this car, but I have had them on older turbo Dodges and SRT4s. I called DSS and essentially they did not want my business, by quoting an absolutely astronomical amount to build a pair of axles for this car. So instead, I made my own hybrid axles from a Crossfire axle and a Dodge Charger axle.
Old Oct 1, 2023 | 09:23 AM
cross2's Avatar
Im in the same boat. They said couldn't do anything with that damm 25 spline wheel hub , It would be have to be bored and resplined , Had me send them hubs and the outboard end of axle over a month ago. And things seem to stall after that point.
Nemiro have you looked into dodge charger wheel hubs as a swap for a larger spline count ? The ABS system and 25 count spline has been the pain in the butt.
Old Oct 1, 2023 | 09:35 AM
cross2's Avatar
Heres a youtube link on what inspired me to do this project Nemiro have a look please
Old Oct 1, 2023 | 09:52 AM
cross2's Avatar
https://gforce1320.com/product/mustang-s550-2015-axles/
I was looking at these axles , I text them to see if hubs could be bored and splined to work with no answer yet
Old Oct 1, 2023 | 05:51 PM
nemiro's Avatar
The closest I have found so far are newer MB hubs. They are the right spline (27, IIRC). However, they use 14mm wheel bolts, which I have not tried with the CF wheels. However, if those were to work, then the whole axle problem starts to get pretty simple, pretty fast. I just have yet to order some.
Old Oct 1, 2023 | 06:30 PM
cross2's Avatar
Isn't the charger and 300 RWD use that 27 spline ?
Old Oct 1, 2023 | 06:41 PM
nemiro's Avatar
Yes. I do think there is commonality there.
Old Oct 4, 2023 | 08:24 AM
cross2's Avatar
Just received my answer back from Gforce on if they could adapt there mustang 550 axles crossfire and here is the answer
Yikes... 25 spline is incredibly small, and I'm guessing you wouldn't have enough room in the hub to go to a 32 or 33 spline. On top of that, it's not just the spline count that you have to deal with; It's how the outer stub flange interfaces with the wheel hub and knuckle assembly, as well as any ABS requirements... I'm afraid we're not currently in a position to help out with something like that
Old Oct 4, 2023 | 10:10 AM
nemiro's Avatar
You may have to parts bin engineer this, with CF outer joints. I used an aftermarket brand of axles, by buying 2x CF axles, and 2x of Charger/Challenger/LX axles, and shopped by specification to get the length I thought I'd need, and then disassembled, swapped parts around until I got what I needed. Tedious, but it worked. I cannot stress enough, use the same brand, as they will tend to stick to common items that can be swapped between joints.
Old Oct 5, 2023 | 08:53 AM
cross2's Avatar
Would you happen to know which models or pt # for these hubs ?
Old Oct 5, 2023 | 10:47 AM
nemiro's Avatar
I think they were for an E55. I would have to go back and look. I researched this years ago at this point.
Old Oct 5, 2023 | 01:00 PM
I don't understand why u would go to that expense when we have a Mercedes and or a Dodge rear pumpkin, in 2.89,, 3.07,,327,,3.45 ,,3.69 and 3.90 all are a bolt in and reprogram your Tcu (no tcu needed with stick shift),, for 10 years , I ran my first V8 with 575 hp at the rear wheels over 600 runs down the 1/4 mile no breakage just drive 55 miles to the track get 3 to 5 runs in the 10's best was 10.55 @ 132 all for less than $3000 rear end including a wavetrac the best rear is the 3.45 ,,,in my srt6 I just ran 12.008 @ 114 with open rear and street tires jim
Old Oct 6, 2023 | 08:43 AM
cross2's Avatar
What i found is the C63 C250-C350 E350-550 sl550 , But I see they use 4bolt bearing mount so its hard to tell if its the same O.D on hub. If its the same spline and size as the older dodge 27 spline the game gets little easer ?
Old Oct 6, 2023 | 11:27 AM
nemiro's Avatar
That's not it.
waldig
Aug 2, 2017 05:35 PM
BMass
Feb 9, 2015 04:27 PM
bruce001
Jan 2, 2014 08:34 PM
SNAKEWOLF
Jan 15, 2010 12:07 PM
srt6
Jun 16, 2006 08:42 AM
