Top & spoiler Inop
Old Feb 28, 2024 | 12:16 PM
MDKEEHN13's Avatar
Default Top & spoiler Inop
2005 limited roadster.
I am prepared to be scolded for my post, I have watched all of the great you tube videos and searched posts on the forum. But I’m still unable to find the fix for my Top and Spoiler issue.
1. All switches APPEAR to be In good shape
2. No water damage in trunk.
3. My key fob locks and unlocks both doors and trunk.
4. When I turn the D ring, both windows go down.
5. When I press the top down switch, I get a beep. But my trunk doesn’t lock. From my understanding the trunk should lock to tell the PTCM it’s safe to lower the top.
6. The top down switch flashes for a few minutes, and then the light on the switch goes out.
7. Spoiler switch light is a continuous flash. And doesn’t move my spoiler.
8. I Assume the vacuum pump works since my door locks work with fob and lock button on dash.
9. I have tried the to resync the top by performing the complete open and close top manually 3 times. While car is running.
10 hydraulic fluid in reservoir is just above minimum line.
11. All fuses are good.
Hopefully I didn’t miss any information that would help in diagnosing these issues.
Thanks to everyone
Old Feb 28, 2024 | 01:18 PM
Default Re: Top & spoiler Inop
Have you used the search function in the top R/H corner? I turned up several leads.
Old Feb 28, 2024 | 02:02 PM
So does the wing stay up or down? You say it is "inop" but that does not tell the entire story. We've got to know exactly what's going on with it.
The top and wing both depend on:
1) The brake controller/wheel speed sensors working correctly.
2) The CLP/SSM working correctly.
3) The BCM passing information correctly between brake controller/PTCM/CLP-SSM.
The conversation between those three modules is complex and the function of both TOP and WING can be inhibited by the same failures. WHile it is possible you have a top issue and an unrelated issue screwing up the wing, my strongest suspicion is that the CLP-SSM is at the center of the problem you have. I cannot say for sure, as again, the brake controller is part of this. And we are seeing, on Facebook, a slowly building up of the number of BCMs that are dying.
BCM? We've had one top that would not move. We've had one car with no turn or hazard signals. We've had one where the top, wing, and wipers would not work. ALL of these were cured with a replacement BCM. I THINK we are all about to learn just what the BCM does!
I would URGE you to tear the CLP/SSM out of it's insulated jacket; unplug EVERY connector and look CLOSELY for corrosion from water intrusion on the connectors. Also, look the CLP/SSM over carefully but I don[t suggest you take it apart. My first suspect is that damn CLP/SSM - and the door locks working DO NOT completely clear the CLP/SSM of fault.
Bob and Patty in Eureka springs had a nonworking top and a frozen wing but their alarm and door locks worked just fine - it was the CLP-SSM. I was at least the third person to work on the car, others had made up their (arrogant and ignorant) minds that the CLP-SSM "could not be bad".
Old Feb 28, 2024 | 02:08 PM
JSK's Avatar
JSK
When the top is manually lowered wouldn’t it be interesting to know if the top will go up with the dash switch?
Old Feb 28, 2024 | 04:43 PM
DTMenace's Avatar
Have the battery tested to see if its output is greater than 12 volts. The electronics are very sensitive to less than 14 volts of battery output. even with today's escalated cost for auto parts, it may be wise to replace the battery every 3-4 years to maintain the system at optimum performance.
Good Luck.....
Dennis
DTMenace
Old Feb 28, 2024 | 04:47 PM
MDKEEHN13's Avatar
I will. Heck again. Thank you
Old Feb 28, 2024 | 04:49 PM
MDKEEHN13's Avatar
No it won’t. Still a beep from top up and down switch thnks
MDKEEHN13's Avatar
Yes it’s 14 volts,
Old Feb 28, 2024 | 05:00 PM
MDKEEHN13's Avatar
Thanks much Piizzaguy.
The spoiler is in the down AND I. THE SEATED POSITION.
I KNEW I WOULD FORGET SOME CLUES, YES MY BAS AND ESP LIGHT IS ALSO ON.
I REPLACED THE FRINT PASSENGER SPEED SENSOR.
TRIED TO RECALIBRATE THE STEERING BY DOING THE lol the way left and right to no evail.
When you mention brake controller, is that referring to the brake switch for the pedal?
I will dig into the CLP-SSM as you mentioned
Again, all help is greatly appreciated, many issues resolved because of you guys. 🙏
kztkadir
Apr 21, 2021 02:03 PM
Jdabs
May 5, 2020 10:13 PM
Red Runner
Oct 18, 2016 01:32 AM
nbmason
Apr 20, 2016 07:06 PM
