Stating issue
Old May 20, 2024 | 01:36 PM
Willard22258's Avatar
Default Stating issue
2008 Crossfire it will only start with a booster. Runs good but once the engine is turned off it won’t start unless it’s boosted again. Installed new battery cleaner and tightened cables but having same problem
Old May 20, 2024 | 06:10 PM
Default Re: Starting issue
New battery needed, most likely. If you don't want to spend a lot of money, get one from Walmart. It will last 4 years; possibly 5 depending on your driving habits. Size 48 / H6
Old May 20, 2024 | 07:19 PM
Default Re: Stating issue
Welcome to the forum.
It sounds like you have a dead cell in your battery or a grounding issue.
I suggest you read this. It will help you out quite a bit when asking questions about your car.
New members asking for tech help
Old May 20, 2024 | 08:57 PM
With a new battery, you must have a connection issue at the terminals.
Old May 20, 2024 | 10:12 PM
Battery cleaner?
Old May 21, 2024 | 07:50 AM
I'd make sure that the battery terminals & cable connections are clean. Curious whether it might be an alternator going bad. If the alternator is going bad, it possibly isn't providing enough current to keep the battery charged up while running the car. Could explain why you need a 'boost' to start the car because the battery is providing power required to operate the car. That would drain a battery right down.
a12052
Aug 17, 2022 12:35 AM
griffinregan
Jun 19, 2022 06:18 AM
shyloe
68
Dec 9, 2017 11:54 AM
poolboy
Mar 16, 2012 01:44 PM
KROSSFIRE1988
38
May 4, 2010 04:54 PM
