Biggest stereo bang for the buck mod
Old Dec 31, 2012 | 02:53 PM
  #541 (permalink)
dtinker's Avatar
Default Re: Biggest stereo bang for the buck mod
Sounds to me as though you are replacing the old system with a new one that has crossover net works internal to it. If the old system is completely gone and you are running new wire you will not need to do the mod. It is just for the stock system and basically builds a crossover( capacitor) to put power to the woofers and keep or limit power or frequencies to the door speakers which are mid range. This is what I understand is happenning, or something very close.
Old Jan 1, 2013 | 09:38 AM
  #542 (permalink)
SuperD500's Avatar
I have had an issue with the volume of my subs, for which I opened another thread (Little volume from rear speakers), but for which I think it might help some of us here. Because it has something to do with the lack of subs volume/power.
Because our radio is not really an intuitive type, I kept pressing and holding buttons to find out what happens.
You can select sound settings by pressing and holding the OPT button for 3 seconds, until USER appears on the display. By turning the right rotary/push button you can now select USER 1, USER 2, or USER 3. The specific user memory saves the sound settings (BASS, TREB and BAL). Nice, nothing out of the ordinary here.
But now comes the tricky part.
When you press and hold the AUD button for 4 seconds, the tone values for the set user memory (USER 1, 2 or 3) are set to 0 (mean value), LINEAR. Meaning that the factory compensation, specific for our XF, is lost and the radio is set to its standard values, LINEAR, being (whatever) all corrections set to normal. Frequency and volume corrections are lost. Not being BASS, TREB and BAL.
And the tricky part is that this cannot be reversed (turned back) on the radio.
I noticed the clear difference instantly by switching between user memories (USER 1, 2 & 3) and experienced it as a lost volume/power in the subs.
Happily, the factory compensation can be re-obtained by momentarily disconnecting the radio from power. This can be fairly easy done by removing the corresponding fuses, which differ per year and model and can be found in the fuse box in engine compartment, at the firewall at the driver’s side.
Old Jan 1, 2013 | 12:05 PM
  #543 (permalink)
lildaddym's Avatar
Too bad the photos are so small!
Old Jan 1, 2013 | 12:12 PM
  #544 (permalink)
SuperD500's Avatar
Mmmmm, I really don't understand why they're so small, they were bigger when I uploaded them.
They're cuts taken from the (.pdf) radio manual.
I've uploaded them into my photo album, they're bigger there ...
Old Jan 1, 2013 | 12:13 PM
  #545 (permalink)
lildaddym's Avatar
Wonder where that manual is?
Old Jan 1, 2013 | 01:15 PM
  #546 (permalink)
gp1200x's Avatar
SuperD500..
Those photos are fine and large when I clicked on them on my PC.
dtinker and kingtj
Thanks for the info. I wired up a plug in case I ever need to try to mod but I too believe the mod is more to remove certain frequencies from the stock door speakers. With all the changes I made I am starting from scratch probably. I'll update once I get it all back together. This is not something I want to do again....much more work than I wanted to do but my stock radio and pass speaker had to be replaced.
FREE
Anyone need a set of stock tweeters or a good stock door speaker? Pay for shipping..paypal (post office boxes if you want) and I will mail them to you.
Old Jan 1, 2013 | 01:17 PM
  #547 (permalink)
lildaddym's Avatar
I need a subwoofer... I found the radio manual online! PM me if you need/want it.
Old Jan 1, 2013 | 01:45 PM
  #548 (permalink)
Mrmiata's Avatar
Is it this one?
http://www.beckerautosound.com/pdf_guides/om6806.pdf
Old Mar 14, 2013 | 11:12 PM
  #549 (permalink)
2much2handle's Avatar
Yet again another great mod. Still can’t get over how informative this forum has been. I just installed the 220uf capacitors and what a difference in the clarity of the door speakers. I however like the sound of bass and there for turned my bass level to +6 and sounds much better than before the mod. I’m satisfied with the stock system now. No need to add extra weight in audio equipment. Keeping it lean for speed.
Old Apr 30, 2013 | 04:24 PM
  #550 (permalink)
jobiggs's Avatar
Very early in this thread, I compared 4 different cap values and found I liked the 270's best. Either too little bass (too much filtering) or too much bass (no filtering), comes from other values.
I still have a bag of 270's if you want a pair.
Have a pair of caps left by chance?
Old Apr 30, 2013 | 10:06 PM
  #551 (permalink)
SrWilliams's Avatar
I have a brand new pair of caps left that I purchased to install but ended up purchasing a whole new third-party stereo system that allowed me to control bass and the speakers throughout. So, I had no need for the caps.
Brand new and never installed
Old Apr 30, 2013 | 10:42 PM
  #552 (permalink)
lildaddym's Avatar
What stereo system did you get?
Old Apr 30, 2013 | 11:22 PM
  #553 (permalink)
SrWilliams's Avatar
I purchased a 2012 Kenwood head unit and it was the best move I ever made. Really made my factory amp and speakers boom. I did change my door tweeters with Kickers and that really made the system explode.
By the way i was concerned about cosmetics. Concerned that going away from the silver head unit would mess the look of the interior up. Wrong!! The black head unit actually looks better than the silver head unit. Consider it
Old Apr 30, 2013 | 11:31 PM
  #554 (permalink)
Default
did you use the factor amp to power the subs only and the head unit for the door speaker? if so was It a pain in the neck to wire everything up? Reason I ask is there's a thread on how to do it but looks like way more trouble than it's worth.
Old Apr 30, 2013 | 11:38 PM
  #555 (permalink)
lildaddym's Avatar
I was curious about which head unit...
Old May 1, 2013 | 12:24 AM
  #556 (permalink)
SrWilliams's Avatar
NO, I used the factory amp to power everytjhing just like it does stock, but I did not use the pre outs from the head unit. It was really easy because I had one of the forum members walk me thru how to wire everything directly into the factory amp and my gosh it was easy.
The factory amp was more than enough power to push the Kenwood. In fact, I can only turn the volume up 3/4 ways and it is blasting. WIth the factory unit I had to turn the volume all the way up and it still was not loud enough for my liking.
But I am going to tell you the key. One of our forum bros on here who was guiding me thru all of this told me to go and purchase these Kicker tweeters and keep all of the subs and mids stock. I was skeptical, but let me tell you those kicker tweeters really amplify the rest of the system.
I saw where the other forum meber wants to know the kenwood head unit I purchased. It is 12:00 in the morning here on the East Coast. I promise tomorrow morning I will go out to my car and actually get the unit I purchased. I promise.
If you guys are serious about your inguiry I will get the more detailed info on exactly how I hooked everything up and just how easy it was. Trust me, I am not electrically inclined and so if I say it was easy it was.
One last thing the forum member who told me to get the kicker tweeters, assured me that my system would sound like a competition system even with the stock subs. He was so right. I have a Porsche 911 that I put in car shows and that I installed this real expensive double din system in it with three TV's in the interior and a 15" TV monitor in th front trunk. The cheap kicker tweeters I put in my crossfire are blowing away the super expensive system I have in the porsche to the point that I am thinking about yanking the speakers out of the porsche and replacing them with the kickers. This will be a shame because the speakers in the porsche are 8 months old.
I know I am being vague in my replies because I am not tekkie person, I am just telling you that the modification that I did with my system, with little or no effort, is blowing my mind.
One last thing, you guys referenced the tutorial that appeared to be more hastle than help. Well i ditched that and went by the step by step instruction given to me by one of our forum members who whowed me how to hook the Kenwood directly up to our factory amp. And doing this way you do not need an aftermarket amop because the factory amp puts out more than enough power if you have the right head unit attached to it.
Also, I first purchased the Alpine head unit for looks and quality. But it was so spartan and it did not provide the indepth settings that the Kenwood provides, which is what allows you to do away with the CAPS in the doors. Because you can control the amount of bass going to the doors by the Kenwood settings. I could not do this with the Alpine
Old May 1, 2013 | 12:43 AM
  #557 (permalink)
STEPHENJXN's Avatar
I would LOVE to see your step by step guide of how you did this + the Kenwood unit you bought.
Old May 1, 2013 | 01:30 AM
  #558 (permalink)
I to would love to see your step by step instructions and would also like to know which Kentwood unit you went with. Thank you in advanced for your time and effort.
Old May 1, 2013 | 01:08 PM
  #559 (permalink)
maxcichon's Avatar
Sure. PM me. I have a bunch already made up for easy install.
Max
Old May 1, 2013 | 01:32 PM
  #560 (permalink)
Easley15's Avatar
Just did this mod.... And all I have to say is WOW
