Unlock all / or just the driver door
Old Apr 4, 2006 | 12:03 AM
RowdyRoadster's Avatar
Talking Unlock all / or just the driver door
I knew this existed and it always bugged me that I had to hit the unlock button twice everyday after work to put my laptop in the trunk. I searched and searched but no luck so now that I found it, i'm posting for others to find easy.
From the service manual:
The keyless entry system has a Global or Selective mode function for central locking that can be programmed by the customer. The factory setting is Global, which will lock and unlock both doors, rear liftgate and fuel door centrally when the respective button is pressed once. The Selective mode will only change which power locks unlock. To activate the Selective mode, press both the Unlock and Lock buttons simultaneously for approximately five seconds until the battery check lamp in the transmitter flashes twice. The Unlock button will then only unlock the driver door and the fuel door when it is pressed once. Pressing the Unlock button a second time, unlocks the passenger’s door and the rear liftgate. The factory setting can be restored by pressing both the Unlock and Lock buttons simultaneously again for approximately five seconds until the battery check lamp in the transmitter flashes twice.
Mine was in the selective mode when i received it so i'm not sure what the actual default is. Anyway i'm global now! I love this board!
Old Apr 4, 2006 | 11:12 AM
MI Roadster's Avatar
Default Re: Unlock all / or just the driver door
Sometimes it's the little things in life that makes us happiest!
Thanks for the info Rowdy!
Old Apr 4, 2006 | 12:55 PM
Fritzauf's Avatar
WOW! Yet another amazing feature to impress my family and friends with!
Thanks for the info.
Old Apr 4, 2006 | 01:43 PM
PJA's Avatar
PJA
Thank's for the info. I'm now "Global".
Pete
Old Apr 4, 2006 | 11:06 PM
04Fire's Avatar
GOING GLOBAL BABE, OUT OF CONTROL!
Old Apr 6, 2006 | 08:53 AM
kmag50's Avatar
Did it last night and it worked great...thanks for the info...learn more about this car everyday!!!
Old Apr 6, 2006 | 09:15 AM
porterhouse's Avatar
Thank you. Now I am global as well.
Does all US models pre programmed at Selective or Global?
Maybe it is time for another poll.
Old Apr 6, 2006 | 06:08 PM
RickB's Avatar
I thought I was going to wear out the button, having to press twice as often to get into the trunk or unlock the door for my wife. Thanks for the info, I'm now global and it has reduced one more irritant in my life.
Old Apr 6, 2006 | 09:32 PM
Your wife probably appreciates not having to ask you to unlock it for her, too, hah!
Old Dec 26, 2006 | 11:04 AM
bobs's Avatar
Resurrecting an old thread here, but I discovered something new. The selective/global mode is a function of the remote and not the car itself. Meaning you can have one key set for selective and one set for global. Pretty cool if you ask me!
Old Oct 24, 2020 | 06:55 AM
Kevinlefevremaiden's Avatar
When I open the driver Door from the INSIDE, all locks open. Is there any way that just the Driver door can be unlocked?
Old Oct 24, 2020 | 06:42 PM
I actually think there is... I just can't remember where or when this was discussed, but I THINK I remember a car being set for that - and the owner wanting it set back to how your (and my) car is set up - cause he found it inconvenient.
Old Oct 24, 2020 | 07:07 PM
I only heard of setting the FOB to open only the drivers door upon one click but never heard of the ability to 'unlock' only the drivers door from the inside using the button on the console. IF it isn't possible to program the console button, you can use the FOB 'drivers door open only' programming function before exiting the car after shutting it off, as an option, ok? Just remember if you have more than one person in the car OR something to get out of the hatch, you MIGHT have to resort to hitting that FOB unlock button twice (again, I believe).
Old Oct 24, 2020 | 08:14 PM
Disconnecting the battery cancels all custom settings.
Old Jan 22, 2021 | 05:03 AM
AlCapone's Avatar
My key fob is set to: One press unlocks the driver's door, a second press unlocks the passenger door and trunk/boot lid. One press locks all three doors. When inside the car, the lock/unlock switch on the console locks/unlocks all three doors simultaneously. With all three doors locked, just pulling on the driver's door release handle unlocks all three doors. If you want to unlock just the driver's door while sat in the car, you will need to use the unlock button on the key fob.
blackcrossfire07
Oct 14, 2009 06:27 PM
fyrepower
Mar 31, 2008 10:05 AM
polmstead
May 9, 2005 07:06 PM
rpr1bob
Apr 19, 2005 05:53 PM
Steffen
Feb 20, 2005 06:47 PM
