Tranny Trouble Question? No Dipstick?
Old Nov 27, 2007 | 12:11 PM
rakoom2002's Avatar
Default Tranny Trouble Question? No Dipstick?
Okay, where do I begin. First off, I am having issues with my tranny. I don't exactly know how to describe whats going on but I will do my best.
The other day I was going up the hill to get to my house and I hear this loud, kind of grinding noise, right below my seat, It seemed also that my car was losing power to the wheels. I could hear the engine working fine, but as I pressed on the throttle to get some more power the noise would get louder and it felt like the tranny was shaking, as if it were slipping.
This issue is intermitant however, itll happen, and I will let go of the throttle, then get into it again and it will hapen again, I will rinse and repeat then the car will work fine. The car will continue to work fine for a while, few days go buy and it will happen again.
First thought was that it might be low on tranny fluid. I pop my hood to find the tranny fluid dipstick and cannot find it. I go into my manual and look up tranny fluid in the index, and find the page. It says something to the affect of "regular maintanaence and checking up transmission fluid is not necessary for your convienance, so the dipstick has been omitted. To check fluid levels take to your local dealer"...blah blah blah.
Say I take my car to the dealer, and there is an issue, and it is related to there not being enough tranny fluid, is this my fualt, or covered under warranty? How am I suppose to monitor the levels if there is not dipstick.
If this issue is just because of low fluid levels and adding fluid can repair it, does this still qualify me for the loaner program?
Old Nov 27, 2007 | 04:01 PM
CrossfireLTD's Avatar
Cool Re: Tranny Trouble Question? No Dipstick?
The tranny is sealed from the factory, fluid can only be checked by a Xfire Tech. Chrysler has a dipstick tool that is only available to the Techs, unfortunately you will have to take it into the dealer. There is a TSB for tranny "O" ring weepage/leaking,TBS: 7-May-05 - 21-002-05A - Auto Trans - NAG1 Fluid Weepage and or Leaks.
Old Nov 27, 2007 | 05:24 PM
rakoom2002's Avatar
Default Re: Tranny Trouble Question? No Dipstick?
would this weapage, be causing this possibly?
Old Nov 27, 2007 | 05:26 PM
Iamfink2's Avatar
It could be but you would see transmission fluid on the ground under the car.
Old Nov 27, 2007 | 05:32 PM
marauderroy's Avatar
Try this, I did a quick search and found a ton of trans info.
https://www.crossfireforum.org/forum...earchid=297790
Old Nov 27, 2007 | 05:54 PM
strupgolf's Avatar
Man, another quirky thing about these cars. I've never heard of a car with no tranny dipstick. What's next, no spare tire.
Old Nov 27, 2007 | 06:11 PM
rje_nc's Avatar
This is actually quite common. Many GM cars have not had auto transmission dipsticks for years. My wife's '99 Olds Cutlas and my Daughter's '03 Sunfire both are without a trans dipstick. The dealer can install one (for a price of course).
I agree that this is a very customer hostile way to save a couple of dollars on the BOM.
Old Nov 27, 2007 | 06:15 PM
strupgolf's Avatar
Well now, I've learned something new today. Good day.
Old Nov 27, 2007 | 06:16 PM
old man's Avatar
off question, how can we make the trans to shift more positive? it seems to slide through the shifts.
Old Nov 27, 2007 | 08:50 PM
rakoom2002's Avatar
Does the crossfire have a CVT Transmission?
Old Nov 28, 2007 | 02:50 AM
VQ35DE's Avatar
No. It a 5-speed automatic.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
