Cabin Filter and Base Coupes
Old Dec 3, 2007 | 07:39 PM
pe3046's Avatar
Default Cabin Filter and Base Coupes
So according to to the 2007 and 2006 vehicle comparison on the chrysler website the base coupes do not have "air filtering." But my car does have the filter (I bought a charcoal one to replace it) but after 4,000 miles the original filter looks clean. Is it just there for show on base coupes?
Old Dec 4, 2007 | 04:59 AM
maxcichon's Avatar
Lightbulb Re: Cabin Filter and Base Coupes
I'm not sure, but I think the replacement is listed as a "B" maintainence item. 15,000 miles or so.
Check your schedule.
Old Dec 7, 2007 | 06:02 AM
pe3046's Avatar
Default Re: Cabin Filter and Base Coupes
Finally got the charcoal one in and installed it last. The original looked clean but upon further inspection it did contain a lot of leaves and other things. So the base coupe does seem to have some form of filtering.
Old Aug 21, 2008 | 06:14 PM
brucero's Avatar
I have an 07 base coupe, I'm trying to determine if a cabin air filter is in the car, or if one can be installed.
How did you gain access to where the filter was.
I looked under the passenger footwell area, and there is a plastic perforated piece there with no obvious access.
Should I start unscrewing stuff, or can you give me some hints or directions.
Old Aug 21, 2008 | 06:23 PM
70GT6's Avatar
While under there - you can see the fan motor. There are white/yellow clips that hold the motor& fan in the car. About 6 inches toward the center of the car there should be a 2" x 8" (about) rectangle piece of plastic held by clips similar to those on the fan motor. Sliding the clips releases the cover and reveals the filter. Pull down to remove filter (if there)
Old Aug 22, 2008 | 03:36 PM
brucero's Avatar
70GT6,
Thanks for the information.
There is nothing under the passenger foot well on my 07 Base Coupe other than a large perforated piece of plastic which covers the entire area.
It seems to be held in place by two screws right behind the glove compartment.
Can't see the fan, or anything for that matter.
There is supposed to be a kneee airbag on the 07's and maybe that plastic shield has something to do with the bag... don't know, but I'm not going to play around removing stuff that could go boom....
I appreciate the reply,
Bruce
Old Aug 22, 2008 | 03:48 PM
strupgolf's Avatar
If you are taking your filters out and they are mostly clean, why cant you just blow them off and re-install? Or just drive without one. Like he said, it looked mostly lke leaves etc. Just asking.
Old Aug 22, 2008 | 03:55 PM
70GT6's Avatar
70GT6,
Bruce
Passenger airbags are in the door and on top of the dash.
There are 2 screws that you remove to drop the perforated panel that you are seeing. Then you will be able to see the base of the fan/motor, and filter base (an the clips holding them in place).
As for cleaning the filter I guess you could - except one type of filter is charcoal made to filter oders - when these go bad your interior has a "pickle juice" smell (someone else came up with that but it is fitting)
Old Aug 22, 2008 | 04:37 PM
brucero's Avatar
70GT6,
Thank You, Thank You..
Removed the two screws holding the perforated panel in place, pulled the panel down, found the air filter box. undid the two clips, and lo and behold, not only a box for the filter, but a charcoal filter installed......
Huh! and in a 07 base coupe.... No mention of a cabin air filter on anything printed..... or the window sticker..
Well, I won't have to worry about getting a filter for a while.. I only have 2K on the car.
Thanks to everyone for all the information that has been posted . It is a treasure for a newbie, and I appreciate all your efforts.
Bruce
Old Aug 25, 2008 | 04:41 PM
BlackCrossFire6spd's Avatar
I've got an 05 base and it came with a cabin filter. I found out when I went to install the new one i purchased because i thought i didn't have one. Those of you who installed a charcoal filter, do you notice any difference in the air quality? where did you purchase it?
Old Nov 29, 2008 | 07:15 PM
Kit Fox's Avatar
+1 on the question above me too, is there an improvement with charcoal and where did you guys get it?
Dust Filter
Nearly all dust particles and pollen are filtered out before
outside air enters the passenger compartment through
the air distribution system.
That is the only mention of the filter on page 116 of 04 owners manual. Thats it..... no mention of how to clean or how to access. Service manual has no hits for "dust filter" or "cabin filter" either. How odd.
Old Nov 29, 2008 | 08:09 PM
70GT6's Avatar
Yeah - no more "pickle juice" smell.
Buy on Amazon - free shipping.
Old Nov 29, 2008 | 08:12 PM
Kit Fox's Avatar
I love amazon, thank you for the link 70GT6, although it does not say anything about it being charcoal, I assume it still is correct?
Old Nov 29, 2008 | 08:29 PM
70GT6's Avatar
C3870 is Charcoal (carbon)
P3870 is a Particulate filter.
Old Nov 30, 2008 | 09:46 AM
supercrossfire's Avatar
what button do i push to turn the cabin filter on and how can i tell if it on does it filter whats in the cabin of the car. for example if i was smoking a ciggerette would the smoke filter out thru the filter in the car?
Old Nov 30, 2008 | 10:53 AM
Kit Fox's Avatar
Cabin filter is always on. It filters all air incoming from the outside through the venting into the car. It works on air coming in, not smoke going out. Not sure about if you recirculate the air.
Old Nov 30, 2008 | 11:25 AM
Posted by Andrew....
once you remove the lower cover/panel under the glove box & passenger foot well area.
this is what you see...
you need to slide back each clip (off white color) to remove filter cover... then pull filter out (it stands up on end).
pic of cover removed:
pics of filter at 25k (new - old): revised m/b part number
Old Nov 30, 2008 | 12:13 PM
cought in crossfire's Avatar
one question is this filter another dealership item
Old Nov 30, 2008 | 12:27 PM
It's available at many websites. here is one for example
Old Dec 1, 2008 | 07:05 AM
gibsonjunkie's Avatar
I got one at Autozone - My Base Roadster had one, too - even though it wasn't advertised.
