Strange Noise From rear?
Old Jan 11, 2008 | 10:04 PM
addie18's Avatar
Exclamation Strange Noise From rear?
I test drove a crossfire today and there was an odd whining noise coming from the rear. I was just wondering if anyone has expierienced this? It only happens when you rest your foot against the gas pedal. Thank you for any advice/input!
Old Jan 11, 2008 | 11:33 PM
sonoronos's Avatar
Default Re: Strange Noise From rear?
In my experience, whining from the rear is from a bad pinion gear in the rear differential.
Is this a used car? Is it a manual or an automatic?
Pinion gear repairs are expensive.
In any case, whining coming from the rear of the car is definitely not normal.
Old Jan 12, 2008 | 06:55 AM
Fenwick223's Avatar
Does it appear more noticeable at speed? I had what some describe as a "humming" noise coming from the rear end. Mine is an '04 and from this forum I learned that it was common with some of the early builds. Took it to the dealer and they changed the rear differential under my MaxiCare warranty and voila - no more noise. Just the sweet sound of the exhaust.
Old Jan 12, 2008 | 11:49 AM
addie18's Avatar
It is a used car but it is still under the powertrain warranty. It is a carfax certified one owner and the book said the warranty would transfer to the second owner. Would this repair be covered under that warranty?
Old Jan 12, 2008 | 12:32 PM
Shawnkey's Avatar
yes it would
Old Jan 12, 2008 | 02:38 PM
beasticles's Avatar
addie read through these threads it will give you all the information you need to know about "gear whine" in the differential. Early 04 models had a faulty differential that eventually whines due to misalignment when driving at higher speeds. Its covered by the powertrain warranty if that car has it. Its a one day fix. However if its not under warranty forget it, the part costs about $3000. Make sure to read these threads...
https://www.crossfireforum.org/forum...t=differential
Old Jan 12, 2008 | 02:40 PM
beasticles's Avatar
P.S. there is not doubt in my mind thats what the problem is, the whining occurs when you press the gas pedal, thats a dead give away.
usprb1976
Apr 4, 2024 04:57 PM
Jonacross
20
Jul 17, 2017 11:19 PM
nataliefs
Oct 5, 2015 01:03 PM
cppeabody
Sep 15, 2015 08:43 AM
xjken
Sep 13, 2015 10:18 PM
