1st Gear RPM Nanny
Old Feb 9, 2008 | 08:39 PM
The_Cohort's Avatar
Question 1st Gear RPM Nanny
你好,
Today I pulled fuses 17 and 18 to test the ability to rid myself of the traction nanny which worked as I saw in past forums. However, now I'm trying to rid myself of the 1st gear 4200 RPM limiter. Has anyone successfully accomplished this? Thanks.
Old Feb 9, 2008 | 09:09 PM
sonoronos's Avatar
Default Re: 1st Gear RPM Nanny
Why do you want to disable "launch control"...?
Old Feb 9, 2008 | 09:37 PM
apkano's Avatar
Life is random...so am I.
I'm not sure what you mean by 4200 rpm limiter, I've only heard about the 5000 RPM limit........I'm the one who disproved the RPM limiter with the fuses pulled......youtube video that ended that thread here
http://www.youtube.com/watch?v=RwRK97G2lFM
There was also some discussion that there was a diferrence between model years, that might be what you are experiencing.
As far as entering "dyno mode"......either have your ECU hacked or find someone with the Mercedes "STAR" software and breakout box and it's possible.
I just threw this video in for fun......it's a no fuses and disabled yaw sensor run from behind a Dodge dealership.
http://www.youtube.com/watch?v=R11E_lsY2B0
Old Feb 9, 2008 | 10:36 PM
downwardspiral's Avatar
2 questions.. How do you disable the yaw control and when all is said and done, does it leave any kind of "footprint" in the computer that the dealership can trace?
Old Feb 9, 2008 | 10:42 PM
The_Cohort's Avatar
I have an '05 XF. When sitting on the line and reving the engine up the limiter kicks in at about 4200 RPMs and prevents going any higher. I was wondering if there is a way to do away with this. I'll have to view your video tomorrow at Starbucks since the Academy censors YouTube from us . I thought pulling fuses 17 and 18 disabled the yaw sensor in addition to the traction control system?
Old Feb 9, 2008 | 10:52 PM
sonoronos's Avatar
The neutral limiter is set at 4500rpm, not 4200 rpm. It serves two purpose: 1 - Launch Control. 2 - Saving your engine on missed shifts.
You're not buying anything by revving past 4500rpm at the line.
Old Feb 9, 2008 | 11:00 PM
The_Cohort's Avatar
Oh...well then mistitled thread. Thanks for the correction and info. I could swear for some reason mine stops advancing before 4500 in neutral.
Old Feb 9, 2008 | 11:07 PM
bump ineed10characters
Old Feb 10, 2008 | 09:58 AM
apkano's Avatar
Just disconnent it.......and as far as leaving a "footprint"....who knows? At worst it'll just show as an open connection that they might think about fixing......but knowing the stealership, they'd never think to even look. Hell, even if they did they'd just scratch their heads and look puzzled!
Old Feb 10, 2008 | 10:02 AM
apkano's Avatar
If I launch at 4500 rpm all I do is make tire dust and a lot of noise. not what I'd call a launch control in the proper sense.
The neutral limiter only kicks in when the front tires are not turning......there's a front to rear percentage differential in wheel speed that kicks this in....if you're going over 20 MPH and miss a shift the car will bounce the redline limiter.
jimf
Oct 10, 2015 10:22 AM
Oct 1, 2015 01:42 AM
rfourt
Sep 25, 2015 01:38 PM
Calitony
Sep 24, 2015 12:53 PM
PA/XFIRE
Sep 5, 2015 01:25 PM
