Window alignment !
Old Apr 18, 2008 | 07:27 AM
Stogey's Avatar
Default Window alignment !
The window on the passenger side is not aligned properly to gasket on upper most rear corner of the window. The corner of the glass is probably a 1/16 of inch from lining up flush with the rear glass. Seems like you could easily slide a business card in between the window and gasket. The doors is aligned to the body as close as I can tell, so I guess my question would be, is there an adjustment inside the door panel to bring the rear edge of the glass in towards the gasket ?
I know there are TSB's out there, but my ride is outta warranty, just wondering if anyone has had the same issue and addressed it ?
Old Apr 18, 2008 | 08:34 AM
spensley's Avatar
Default Re: Window alignment !
I think if you remove the inner door panel there's a couple of screws which will realign the window correctly.
Start by using the search function, it's on this forum as is every other Crossfire problem you can think of!
Old Apr 18, 2008 | 08:39 AM
Stogey's Avatar
Yeah, did a search which refers me to the TSB's which does me no good !
Ain't takin the thing to the Stealer being it is out of warranty !
Just wondering if anyone had this issue and what they did to fix it.
Old Apr 18, 2008 | 08:49 AM
+fireamx's Avatar
Stogey, somewhere there is a photo (on the forum) of the Crossfires door panel removed, and the plastic sheathing pulled up to show an access hole to an adjustment bolt at the bottom of the window. It looks as though you may need a special tool to fit the bolt though.
I never have much luck when ever I use the search feature, and couldn't find it. Maybe somebody will remember where it is, and post it.
Good Luck
Old Apr 18, 2008 | 09:18 AM
Stogey's Avatar
Thanx AMX !
I was looking at pullin that door panel off anyway, just preparing myself for what I might find underneath it in way of special order parts and or tools !
Just my Dos Centavos !
Valk
Jul 12, 2021 09:49 PM
Nexxus
May 8, 2016 04:43 PM
UNDER PSI
Nov 1, 2015 09:39 PM
Reliableron
Oct 17, 2015 10:19 PM
nataliefs
Oct 5, 2015 01:03 PM
