HELP with noise from behind the dashboard (AC Unit)
Old Feb 4, 2009 | 08:12 PM
blackcrossfire07's Avatar
Default HELP with noise from behind the dashboard (AC Unit)
Hi everyone... I have been lurking around this site for months and have enjoyed the information everyone has shared. I have a 05 base crossfire and have loved it since day one. I had it now 3 and a half years.
The latest problem is the AC unit. The AC unit runs perfectly as it should. The problem is when I turn it off either by the switch or if I turn the engine off while it is running. I hear a crackle and clunk. It practically shakes the dashboard. It almost sounds like the blower is slowing down and rattling because it is out of balance. It makes the noise for a couple of seconds and that is it. I think it also makes the noise when I first turn the fan on but it is very faint.
I have a max care extended waranty so it is covered. I just hate bringing it in to the dealership if it is something I can do myself. I read previous posts that leaves and stuff get in the motor. A month ago I did check the cabin filter and found leaves in it. That must mean they went through the blower first. I hate to admit it is still the same cabin filter that came with the car. I never knew it had one until a month ago. I just got a new MB filter and I am going to replace it this weekend. Could this noise be a result of having an old filter? Do you think the fan blower motor is bad? Or do you think there is dirt and leaves in there or something? I only hear the noise when I turn the fan off... not while it is running. Thanks guys!
Old Feb 5, 2009 | 06:37 AM
Default Re: HELP with noise from behind the dashboard (AC Unit)
One last thing... I am having trouble getting the new cabin filter in. It seems thicker than the original. Anyone else have that problem? It is the right part number because I checked with 2 dealerships. It should be tight but it will fit, right?
Old Feb 5, 2009 | 07:04 AM
It does fit tightly as I recall.
Old Feb 5, 2009 | 08:37 AM
Paul Bosslet's Avatar
When I partially removed the bottom panel that hides the fan motor, there were alot of twigs and leaves and other debris that had to be cleaned out. So change the filter, clean out all the debris and everything should quiet down. Good luck.
Old Aug 4, 2013 | 12:32 PM
HarleyGuy's Avatar
We heard noises in our air conditioning fan motor so I took it apart and cleaned out the filter AND the fan blade housing. We have a 2006 Crossfire, Roadster Limited
I was pretty sure it was leaves and I think the air intake design is bad cause it lets a lot of leaves get into the AC filter area and on into the fan housing
To remove these leaves you have to remove the glove compartment
And then drop the fan FILTER
When we did this we saw tons of leaves in the filter. The filter drops down after you slide the white plastic holders aside
We also had leaves in the fan housing
Whole job took about 2 hours
Old Aug 6, 2013 | 12:01 PM
TXCF's Avatar
Attachment 29017
Attachment 29018
Attachment 29019
Attachment 29020
Attachment 29021
Attachment 29022
Attachment 29023
Attachment 29024
Attachment 29025
Attachment 29026
Attachment 29027
Great write up and pics. I noticed when i have the AC on and step on the gas i get a whistling noise from the right side of the dash. If i let off it stops. Is this caused by filters clogged/leaves and junk?
Old Aug 11, 2013 | 05:42 PM
Rabidraider's Avatar
I had a dead mouse fall out when I checked my cabin filter...
Old Aug 11, 2013 | 05:53 PM
I cleaned that area and changed the filter, and cannot see why you have to do that much work. Take out the glove box is not required unless you like work. You can even get at the fan.
Old Jun 7, 2019 | 08:03 AM
HarleyGuy's Avatar
Yes, it looks like I took way too much apart. And when I put it back the glove box door was not aligned just right so I had to take it all apart again.
Thank you for the input.
ty_ty37
Jun 27, 2024 10:42 AM
Sterling57
Apr 11, 2016 06:11 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
smokey847
Sep 15, 2015 10:47 AM
