How Many Qtz Of Oil???
Old Feb 20, 2009 | 01:08 PM
speeddiva989's Avatar
Default How Many Qtz Of Oil???
How Many Quartz Of Oil Does This Car Take And Is It Synthetic?
Firestone Told Me It Takes 8 Quartz And Is $115.00 For This Mobile W1040 Or Something?
Old Feb 20, 2009 | 01:11 PM
No Warning Shot's Avatar
Default Re: How Many Qtz Of Oil?????
8.5 qts. synthetic. 0w-40 stock weight but 5w-40 is acceptable.
Old Feb 20, 2009 | 02:03 PM
smfrycruzr's Avatar
That's about what I paid for my last oil change. The Mobil One synthetic is produced in a refinery that got damaged last year by one of the hurricanes that went thru Houston area.
Old Feb 20, 2009 | 04:27 PM
antonio311's Avatar
It's 8.5 quarts with the filter. Use only the 0-40 mobile 1 in your srt-6 !
Old Feb 21, 2009 | 10:40 AM
Mimi05SRT6's Avatar
A minimum of 8-qts... You should do it yourself and save a lot of money. I put in AMSOIL 5w-40 with filter for only $70. I refuse to have others do it for me since I've heard horror stories already. It's a very simple process.
Old Feb 22, 2009 | 05:19 AM
Paul Bosslet's Avatar
It uses Mobil 0-40 synthetic. The capacity is 8.5 qts. but only fill it back up with 8 qts. and then check the oil level. Overfilling is worse than being slightly under. There is a oil level sensor that lets you know if the engine oil level is low or high as described in the Owners Manual (or you can always use the old fashion dipstick method).
Old Feb 22, 2009 | 07:50 AM
VQ35DE's Avatar
I used 8 quarts ONLY and it was dead even on full.
Old Feb 22, 2009 | 09:59 AM
Mine only requires 8 quarts with an oil and filter change.
This puts it right at full.
I do my own oil changes and use only Mobil 1 0W40 and a fleece filter.
Old Feb 22, 2009 | 10:12 AM
billangiep's Avatar
Agree....8 quarts with a filter change brings it to the top. Don't know why the manual says 8.5 quarts? Maybe there's a problem with the conversion from liters?
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
lazorouss
Sep 11, 2015 09:16 AM
