Gas Pump Icon
Old Apr 15, 2009 | 09:56 AM
hoopcoach11's Avatar
Default Gas Pump Icon
The gas pump icon on the dashboard, which is supposed to come on in as solid light when you are low on fuel, has been coming on and flashing, and there is plenty of gas in the tank. Does anyone know what this is signaling?
Thank you
Old Apr 15, 2009 | 10:23 AM
blackcrossfire07's Avatar
Default Re: Gas Pump Icon
I could be wrong but I think it means the gas cap is open.... or at least it thinks it is open.
Old Apr 15, 2009 | 10:51 AM
tighed1's Avatar
Yep. Remove and re-tighten your gas cap.
May take a few for it to reset.
Been there, got scared, done that, fixed it.
Old Apr 15, 2009 | 10:57 AM
Beaner's Avatar
The manual said "Leaving the engine running and the fuel cap open can cause the CHECK ENGINE light to illuminate" so a loose cap is not your problem. I will keep lookin!
Old Nov 25, 2022 | 10:26 AM
manlaw38's Avatar
I bought a new gas cap in summer has been fine but now it is cold gas icon flashing when I start car to keep battery charged. Perhaps the seal on the new gas cap is not seating like original. I didn't have to replace cap just did it to keep up on maintenance on an old car.
Old Nov 25, 2022 | 11:12 AM
Flashing means problems with the EVAP system. In time, the condition will set a DTC code and the "CHECK ENGINE" light will light. At that point, you can read the code - it will be one of these, which will point you in a direction to look. A 442 or 445 can be the gas cap. If you bought an off-brand cap with a seal that is not as thick or soft as the OEM one, you won't get the seal the system expects and a leak will be the result.
Old Nov 25, 2022 | 05:37 PM
Thank you
I'd guess it is a fault in the sending unit in the tank or a faulty connection in the circuit.
Old Nov 26, 2022 | 06:23 PM
Thank you
Be sure you tighten the gas cap until you hear the "CLICK". It has to be tightened to this point for it to seal properly.
Old Nov 27, 2022 | 10:19 AM
He says Gas Pump icon not Check Engine icon.
He does not say if it starts flashing all the time or just every now and again.
Last edited by onehundred80; Nov 28, 2022 at 11:43 AM. Reason: I said something that made no sense (again).
Old Nov 28, 2022 | 08:39 AM
richb55's Avatar
could be the “float” located in the tank being stuck or worn
Spector01
Sep 8, 2019 09:57 PM
Tony Palmer
Nov 27, 2014 01:45 PM
welder7018
Nov 13, 2008 12:56 PM
kraz17
Jul 11, 2005 01:02 PM
convertiblenut
May 6, 2005 05:31 PM
