Oil filter query
Old Nov 28, 2009 | 11:03 AM
Roy Mander's Avatar
Default Oil filter query
I have been looking on Ebay for Crossfire oil filters, I have noted that there appear to be two types, one a filter with a set of O rings and sump plug washer, and the other a throw away canister. My car is ans 04 model. and it has what appears to be a throw away canister, or is it a cover for the other type of filter. Can anyone tell me which is correct.
Old Nov 28, 2009 | 11:14 AM
Default Re: Oil filter query
That black plastic cap is kept, not thrown out with the filter cartridge. Get a fleece filter not paper, do a search and you can find lots of threads on this matter. The filter comes with O rings and sometimes a washer. Its best to change the washer for the sump plug, at the price the oil is you do not want to waste it drip by drip.
Old Nov 28, 2009 | 12:51 PM
NAPA...
Old Nov 28, 2009 | 03:14 PM
harbor's Avatar
Roy - Skip e-bay and buy from needswings.com here on our forum. He's got the correct fleece filters & crush washers.
Old Nov 28, 2009 | 03:30 PM
NAPA...
That's what I'm using now. The ones I bought at NAPA don't have MANN printed on them yet say "Made in Germany". They look exactly like the MANN filters I was using.
Roy, stay away from a canister filter!
Old Nov 28, 2009 | 04:15 PM
You should probably go to the forum sponsor, but if not, Advance Auto has Purolator L25277's that are German-made Fleece filters. I paid $11.49 each.
(They also have an L25276 that is a paper filter - I would not use it.)
Old Nov 28, 2009 | 07:23 PM
Are you using the 7078 part number? The 1226 are paper filters.
James
Old Nov 28, 2009 | 09:01 PM
James
Yep, 7078.
Old Jan 30, 2010 | 05:57 PM
Darticus's Avatar
Yep, 7078.
Oil filter 7078 from NAPA is this the correct oil filter? Found 0W 40 mobil oil in Walmart today. I thought they stopped making it. Is there a special way to put the filter in? Do the seals go in a certain way? Should I buy the oil filter somewhere else other than NAPA? Thanks Ron
Old Jan 30, 2010 | 06:03 PM
make sure o-rings are correctly place, look at old filter, and make sure the new filter is seated properly...good luck...you will do fine...easiest oil change I have ever done...I like the top sider...
Old Jan 30, 2010 | 06:18 PM
Darticus's Avatar
Thanks, I go back a few years when oil filters were on the bottom screw in can. I'll have to look for this one. Ron
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
