Shop Manual For Oil Change?
Old Nov 25, 2010 | 05:22 AM
vpats's Avatar
Default Re: Shop Manual For Oil Change?
I’ll add a word here, I put one of the steering dampers on a couple of months after the oil change and having used a jack and jack-stand to change the oil, I decided that an investment in a pair of ramps might be a good idea. I bought some from Advanced Auto, 8,000 lb load rating, best 34 dollars I’ve spent in a while.
The next oil change should be a breeze using these ramps. They are of the non-metal type and have a long entry ramp to the platform, no body scraping and they store easily when not in use.
Old Nov 25, 2010 | 07:07 AM
LantanaTX's Avatar
While I am using Mobil 1, I did come accross a better oil while at a desert off road race with my uncle who is a crew chief and he also helped me with my V8 conversion. There is a synthetic by JGD (Joe Gibbs Driven) that states that it is for off road use only. This is becuase it contains the really good stuff that the EPA doesn't allow.
Joe Gibbs Driven - Racing Oil and High Performance Products
Old Nov 30, 2010 | 11:38 AM
West Peterson's Avatar
Which viscosity of the JGD oil do you use?
Old Nov 30, 2010 | 12:02 PM
Thirteendog's Avatar
Originally Posted by blackcrossfire07
Is there an official manual for crossfire oil changes. I hate to be one of those guys that didn't do a search..... but I did search and found plenty of write-ups here that are real helpfull. Just wondering if there was a manual with detailed instructions. My biggest fear is getting the filter o-rings in the right place.
It has been years since I changed my own oil. Just tired of having someone in the back work on my car and I have no idea if it is being done properly. Or I could go to a jiffy lube and still can't watch these kids properly. I watch them do oil changes and they are too fast and careless. The only person that will do it correctly is me
This is what I do. I slide the filter off, and take the O rings off in order (Small to Big) and line them up as I do it on a piece of card board. Slide the new filter on and measure lay the new O rings above the old ones matching them up. Lube the new O rings and place them back on in reverse order (Big to Small). Double check filter is up as far as it can go and you're good to go.
BTW the order in which you take the O rings off doesn't matter. It's just my OCD kicking in that I do it a certain way everytime. I just know 2 of them are about the same size and I don't want to get them confused. Oh and yes, you will have a left over O ring (pending on where you get your filter)
Edit: Of course I just responded to a thread from August...
Ralph289
Sep 12, 2021 11:15 AM
PNA
Nov 12, 2020 04:44 PM
xfClifford
Aug 3, 2015 11:03 PM
Crossfireconv08
Jul 30, 2015 12:11 PM
skeet370
Jul 18, 2015 01:02 PM
