Another Cup holder problem
Old Mar 26, 2011 | 11:32 AM
arejohn's Avatar
Default Another Cup holder problem
Got the console loose but can't get it off. Got a yellow hose like tube i can't get disconnected.
What's the trick?
Search is your friend. cup holder removal - 3 pages. Cup holder yellow - 6 hits for yellow.
Bet I am missing something other than today's ride.
Update- found out its the air hose for the compartment lock. I can't see it to figure out how to disconnect. Still searching know that I now what I am looking for it might give better results.
Old Mar 26, 2011 | 01:39 PM
rekcah's Avatar
Default Re: Another Cup holder problem
That's an air hose, I believe you just pull it off. Try looking in the roadster forum as the coupe don't have that hose.
Old Mar 26, 2011 | 04:53 PM
arejohn's Avatar
Once I was able to get the console high enough to get my nose under it I was able to see the air switch. Put a flat blade in the side of the receiver and pulled the hose out.
Those German engineers must have had too much time on their hands to design that cup holder.
Interesting that the cup holder worked in Florida when I picked up the car, got intermittent on the way back to NC and did not work at all here. Little latch in rear of the cup holder was binding.
As usual a four hour job that I can to in a third next time.
Old Mar 26, 2011 | 05:43 PM
David Woolrage's Avatar
And, how did you repair it when you got it out or didn't you repair it?
I think if I got it out I permanetly glue it shut if I could? _/)***
Old Mar 26, 2011 | 09:33 PM
rekcah's Avatar
you could remove the spring and it wont pop open anymore.
https://www.crossfireforum.org/forum...older-fix.html
anyone with the storage bin, have the measurements for it? I'm gonna try vacuum molding.
Old Mar 26, 2011 | 10:03 PM
Its been a while now, I installed a storage bin for a memeber in the hotel lot during Woodward. I remember seeing the air line, but think I could work around it without disconnecting it.
James
Old Mar 26, 2011 | 11:29 PM
I worked the airline loose by pulling and twisting gently. Came right off... went back on by just pushing it on the nipple!
Old Mar 27, 2011 | 06:35 AM
PNA's Avatar
PNA
I've seen storage bins advertised a number of places before. Some ideas may be here on the forum as well. I think I've seen them on Ebay too so you may want to try to locate and buy one (if reasonable) before going to the trouble of making one.
Old Mar 27, 2011 | 10:47 AM
Kodebuster's Avatar
PizzaGuy ~ Noticed the bra on your Xfire.
Is this something that Chysler sells, or was it aftermarket.
If you can point me to your source and a price range, it's appreciated.
The lovebug season is coming to Florida, and they are a trip to get off...lol...
I'm figuring the bra might help a little...
Thanx...
tcar32909
Aug 1, 2024 02:41 PM
nataliefs
Oct 5, 2015 01:03 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
cdcrone123
Sep 20, 2015 10:02 PM
skeet370
29
Sep 18, 2015 05:53 AM
