Noisy Interior
Old Jan 26, 2012 | 04:31 PM
hbv2020's Avatar
Default Noisy Interior
I am considering buying a Crossfire. I took a 2007 coupe with only 10,000 miles for a test drive. The road surface was not bumpy but the pavement was very coarse. The noise inside the car was deafening. Sounded like I was inside a drum. I wonder if the four year old tires were the culprit, or if all Crossfires are on the noisy side?
Thanks
Old Jan 26, 2012 | 04:41 PM
frankeyser's Avatar
Default Re: Noisy Interior
Thanks
It could be the tires. My wife and I drive on very long trips with no real problem depending on the roads. You do have to remember that you are almost sitting on the rear tires so you will hear some road noise. We have the BF goodrich G-force tires which I hear are a pretty loud tire but does not sound like a drum at all.
Old Jan 26, 2012 | 05:13 PM
Stargazer's Avatar
We drive the roadster and with previous tires we did get a lot of road noise. That just told us it was time to get rid of them. New tires + 5000 miles and we do not have any extraordinary interior noise.
How is the tread wear?
How is the alignment?
Old Jan 26, 2012 | 05:14 PM
+fireamx's Avatar
Many tires get louder as they age. Some tires are just noisy right from the start. But remember, the Crossfire has some of the widest rear tires in the industry, so a little more road noise is to be expected.
If you're looking at a 2007 model with its original tires, I'd guess that's where most of the noise came from.
I'm on my 4th. set of different brand tires, and every single set had their own distinct sound.
I've owned a couple dozen sports cars over the years, and with out a doubt the Crossfire "coupe" has been one the most comfortable and quiet of them all.
Old Jul 26, 2013 | 05:00 AM
RobF's Avatar
Could a steering shock cause some road noise from the front tires if it is worn?
Old Jul 26, 2013 | 09:32 AM
pjpsrt's Avatar
it's all about your point of reference.
what did you drive to the test drive, and did you drive the same roads?
I found the crossfire noisy at first.
but, I was used to driving my sl500.
a larger, heavier, quieter, and softer riding car
the crossfires and the slk's it was derived from, are smaller, sportier, noisier.
and I might mention much more thrilling and exciting to drive.
Old Jul 26, 2013 | 11:16 AM
AlG's Avatar
AlG
I find the car is terrible when driving on concrete. Macadam not quite as bad. Either way, it's not going to be limo quiet. Sound deadening is not one of this car's best points.
Old Jul 26, 2013 | 12:15 PM
Goldwing's Avatar
My SRT6 is harsher riding and noisier than my roadster. There is tire noise with each, but that is part of the charm of a sports car. We bought a 2007 coupe for my son three years ago and I do not recall it being unusually noisy. When you shop for new tires, have the discussion with the store about road noise. Different compounds can give off different levels of road noise, so shop around. I suspect harder, longer lasting tires are noisier than soft rubber that wears faster.
Old Jul 26, 2013 | 03:06 PM
Sandy's Avatar
I cut and placed 2 layers of carpet insulation under my carpet in the rear. Seems quieter.
Blackly
May 27, 2026 10:15 PM
TerryR
Dec 13, 2019 03:27 PM
ATX SRT-6
Oct 12, 2015 03:16 AM
MiamiTVR
Other Cars Etc
Sep 29, 2015 05:27 PM
jaesa
Sep 7, 2015 01:50 PM
