radiator fan keeps failing
Old Mar 27, 2012 | 10:24 AM
Dannybondz's Avatar
Angry radiator fan keeps failing
im not sure if its the after market fans or what but i have change this fan 3 times and each has only lasted no longer than 1 months time. Eventually the fan cracks and begins to whooble causing the entire car to vibrate. Im nervous of buying the original manufactured fan which is around $350.00 and it does the same thing. Does anyone has any clue to the reasons of my fans constantly cracking also once i do install these fans they al very high sounding like a industrial fan. please help i am so tired of replacing this fan.
Old Mar 27, 2012 | 10:34 AM
maxcichon's Avatar
Default Re: radiator fan keeps failing
In 5 years of ownership. I have heard my fan exactly 3 times. Are you sure the fan speed controller is working? Who has diagnosed this?
Old Mar 27, 2012 | 10:47 AM
Dannybondz's Avatar
I have yet to have it diagnosed i figure since it goes on and off when needed that there was nothing wrong with the fan module, and going tho Chrysler dealership is out of the question there diagnostic is extremely to expensive.
Old Mar 27, 2012 | 10:53 AM
maxcichon's Avatar
Yeah-the fan controller is a true speed controller. If yours is an "OFF/ON" unit I think you've got problems.
I don't know what else to tell you. The fan controller is more expensive than the fan.
Old Mar 27, 2012 | 11:05 AM
Dannybondz's Avatar
okay thank you so much but is the fan speed controller and the fan module considered the same thing?
Old Mar 27, 2012 | 11:30 AM
To my mind they are the same thing, mounted on the driver side inner fender.
Old Mar 27, 2012 | 11:47 AM
maxcichon's Avatar
Yep.
Thanks, Dave.
Old Mar 27, 2012 | 05:54 PM
Check out MrMopar, he's parting out a few XF's might have the fan AND the module!
Old May 2, 2012 | 08:57 PM
Dannybondz's Avatar
Smile Re: radiator fan keeps failing
i would like to personally take this time out to give thanks to the crossfire forum gods. Replaced fan module and fan and the fan runs great no more airplane landings when im puling up. My a/c even blows better, im talking 100% colder. thaaaaaaankkkk yoooouu I love you guys!!!!!!!!!!!!!!!!!!!!!.
Old May 2, 2012 | 09:46 PM
Curious did you go back with OEM parts?
I have not had the pleasure of messing with the fan system on the Crossfire yet. Is the fan blade separate from the fan motor? Or must they be serviced as one? Could your fan blade be out of balance causing the bushing/bearings in the motor to go bad prematurely?
Just something to think about. James
Old May 2, 2012 | 09:48 PM
waldig's Avatar
Talking Re: radiator fan keeps failing
Fan runs on 4 volts and can speed up to about 8-9 volts. 12 volts are dangerous and causes overspeeding of this motor. Never try connecting it direct to battery, OOF that would be bad to do. WOODY
Old May 2, 2012 | 10:05 PM
Mike1118's Avatar
Hummm. Me thinks I may have the same problem. Started yesterday. Also my.low coolant light is coming on and off. Think I am going to.replace this. I had planned on replacing the thermostat and.water pump. Great forum. Thanks guys.
Old May 2, 2012 | 10:50 PM
Just so you know, the low coolant light will also come on if the ECU senses a problem with the Fan Control Module OR if it looses communication with the fan control module.
Old May 3, 2012 | 10:42 AM
Dannybondz's Avatar
reply to james: The fan assembly is one complete assembly, though i have seen the oem fan blade by itself for sell on ebay. I order my fan assembly from amazon and fan module controller from eBay: The Crossfire Shop. I decided to change the entire fan assembly instead of just ordering and then having to return to change other parts.
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
paine2907
Oct 2, 2015 10:01 AM
Oct 1, 2015 01:42 AM
RiderJC
Sep 7, 2015 11:19 PM
