plastic jacking point block
Old Jun 29, 2012 | 02:46 PM
bieber's Avatar
Default plastic jacking point block
I got the oil changed last night on my new (to me) Crossfire, thanks for the help to those that replied to my other post.
I jacked it up per the manual by using a floor jack under the jacking point behind the drivers side front wheel. That point is a plastic block on the rocker and was barely attached. The little fingers on it that retain it into the hole in the rocker were worn (& one missing). I want to try to get one, or at least try to order one, later today.
I tried to find the part in the 2004 parts manual here (thanks guys for that also!), but I failed. Can someone tell me where that sucker is in the parts manual? Is it something common to a Mercedes also?
Old Jun 29, 2012 | 02:51 PM
Default Re: plastic jacking point block
Mercedes W171 W203 W209 E550 SLK500 CLK320 C230 Jack Pad Genuine X 1 | eBay
Old Jun 29, 2012 | 06:01 PM
Toolman's Avatar
The Mercedes jack pad will not fit the Crossfire without modification. Two corners will need to be notched.
The Chrysler part number is 5099715AA. Last year when I tried to order one from OE Discount Parts they cancelled the order saying the part was not available.
Old Jun 29, 2012 | 06:09 PM
Try https://www.crossfireforum.org/forum...-shop.htmlhere.
Old Jun 30, 2012 | 12:52 PM
bieber's Avatar
Thanks for the help, 2 questions.
1) The link did not work.
2) The bottm of my car (see with the pad off) has both a hole for the protruding center part of the pad to go into (the part with the 4 fingers) and there is an inch long 1/4" dia barbed rod sticking out of the rocker panel, it goes into a small hole in the pad itself.
The picture of the pad on ebay is missing the small hole for that rod attached to the car. If I ger the M-B pad, along with trimming ears to make it fit do I also drill a hole in it for the barbed rod?
Old Jun 30, 2012 | 01:11 PM
dinasrt's Avatar
My OEM jacking point pads are also a little buggered up (by the previous owner). What I do is use a 3/4" rubber pad (small piece of horsestall mat) to sit on top of my floor jack. It conforms to plastic pad, protects, and prevents slip outs. I don't sweat the OEM pads being less than perfect because you can't see them without getting upside down, and also they were meant to, well, jack up the car with. I cut a smaller piece for the jacking points, and a larger one to cradle the rear diff. pumpkin. This material holds up to my 4 ton truck; tough stuff.
Old Jun 30, 2012 | 06:05 PM
From an earlier thread.
part#5099715AA
https://www.crossfireforum.org/forum...tml#post262287
Old Jun 30, 2012 | 06:29 PM
bluecoupe's Avatar
Mopar Part 5099715AA SILL JACK BUTTON PAD
Old Jul 2, 2012 | 08:43 AM
bieber's Avatar
Thanks for the help guys!
smfrycruzr
Jul 17, 2023 05:33 PM
rmcdaniel12
Nov 4, 2015 04:08 PM
jimf
Oct 10, 2015 10:22 AM
ritous1
Sep 26, 2015 01:27 PM
tritongreen
Sep 18, 2015 07:32 AM
