Sticky ignition key -- steering wheel removal?
Old Jun 29, 2012 | 04:10 PM
Mopar or No Car's Avatar
Default Sticky ignition key -- steering wheel removal?
I'm trying to follow the sticky ignition key fix document, but my locking pin is not exactly where the photo shows and I can't get the tool in to drill out the pin. The plastic trim around the steering column behind the steering wheel is blocking access. Do I really have to remove the steering wheel and instrument cluster (so says the service manual) to get this trim piece off?
Thanks in advance.
Old Jun 29, 2012 | 05:54 PM
bluecoupe's Avatar
Default Re: Sticky ignition key -- steering wheel removal?
the wheel has to come off, not sure about the cluster but once the wheel is off the cluster bezel and cluster is much easier to remove
Old Jun 29, 2012 | 07:34 PM
I have never saw or heard of removing the steering wheel when doing the sticky iggy fix. Be sure your reading the latest version 2 (although the older one has no mention of removing the steering wheel that I remember either), I just re-read it nothing about taking out the steering wheel.
Old Jun 29, 2012 | 07:47 PM
I think he is missing the part about pushing the plastic part away from the area where the pin is.
Old Jun 29, 2012 | 11:16 PM
I pushed the plastic part away (the half-moon that retracts and goes back into place as if it were spring loaded), but the pin is so far up inside I won't be able to drill it out because the angle is too sharp. It's not accessible like the one in the how-to.
Old Jun 30, 2012 | 01:31 AM
rekcah's Avatar
I'm not sure if there is a difference between the srt6/roadster/n/a/coupe ignition assembly location. The howto is based on a n/a coupe.
telecoping the steering wheel all the way out might give you a little more room.
Old Jun 30, 2012 | 08:13 AM
bluecoupe's Avatar
GG, please re carefully and you won't be confused the OP asked if the wheel has to come off to remove the plastic steering column trim.
Old Jun 30, 2012 | 08:57 AM
I STILL say GG is right. I have NEVER heard of someone taking the WHEEL OFF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If the pin is that far up in the hole, then use a punch pin to make sure it is up in there enough, and start pulling and twisting the lock assembly to remove it!
Old Jun 30, 2012 | 08:58 AM
^^^ Yea! ^^^
Old Jun 30, 2012 | 10:59 AM
OP post and your reply says the wheel has to come off to get into the fix, I read very well...
Old Jun 30, 2012 | 11:59 AM
rekcah has the answer -- telescoping the wheel reveals the pin at an accessible angle. I feel like a dope for not thinking of it myself.
Thanks.
Old Jun 30, 2012 | 12:39 PM
Thanks.
Hey, if its' not in the instructions then it's the writer's fault!
(That is how things go at Kenwood, USA. And since I am now one of the writers at Kenwood USA....)
Old Jun 30, 2012 | 01:18 PM
bluecoupe's Avatar
Are you related to FUBU?
Old Jun 30, 2012 | 04:30 PM
FUBU, Beaner, 13dog and I are all the same person !
Old Jun 30, 2012 | 05:26 PM
Thanks.
Glad you got it fixed! You'll never have that problem again per many who have fixed it over the course of ownership! Now, do we see a 'sticky iggy fix' revision 3 coming soon Rekcah? Something like 'To gain access to remove the pin make sure the steering wheel is pulled all the way rearward so the trim panel can be moved out of the way'??? Whaddya say Rekcah? BTW great call on the solution girl!
Old Jun 30, 2012 | 06:19 PM
bluecoupe's Avatar
I see you are still confused. This is what he asked: "The plastic trim around the steering column behind the steering wheel is blocking access. Do I really have to remove the steering wheel and instrument cluster (so says the service manual) to get this trim piece off?" and this is how I answered " the wheel has to come off, not sure about the cluster but once the wheel is off the cluster bezel and cluster is much easier to remove".
Old Jun 30, 2012 | 07:41 PM
rekcah's Avatar
I'm not a girl.
revision 3 added to the Sticky: sticky ignition key fix thread found here
https://www.crossfireforum.org/forum...tml#post681520
Old Jul 1, 2012 | 02:03 PM
Not worth arguing about, the wheel does not have to come off. He asked if it did according to the manual and you said it did. I'm done with this thread portion, the wheel does not have to come off.
Old Jul 1, 2012 | 02:06 PM
Originally Posted by rekcah
I'm not a girl.
In no way was that meant to be demeaning. Thanks for the revision.
Old Jul 1, 2012 | 02:08 PM
Mrmiata's Avatar
Did I read that correctly? "Deep employee discounts on stereo equipment available here"?
