any one change their manual shift knob yet?
Old Sep 19, 2004 | 01:24 AM
ERCROSSFIRE04's Avatar
Default any one change their manual shift **** yet?
Has any one changed out their manual shift **** for an aftermarket one? Is the xf **** a twist off or is it held by a retainer? i wanted to change mine out only because i do not enjoy the feel of the xf's ****.
Old Sep 19, 2004 | 01:43 AM
AZ Outlaws's Avatar
Default
Check the tech forum for details... a few folks have changed them and posted about it. I believe they said it was a locking ring type...
Old Sep 19, 2004 | 10:43 AM
Default
Az,
Thanks bud!
Old Sep 19, 2004 | 11:01 AM
David Burns's Avatar
Default Re: any one change their manual shift **** yet?
It's been said that aftermarket ***** for the 2003 SLK320 will fit. There are quite a few site's on the net that sell SLK320 parts. And as AZ said, there's been quite a few posts in the past about replacement *****.
Old Sep 19, 2004 | 12:15 PM
Dan Root's Avatar
Banned
Default
HDDP has a MOMO shift **** on his 6sp.
I replaced my auto **** with Momo also ,they make a large selection to choose from .
Old Sep 19, 2004 | 07:18 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default
here it is...
https://www.crossfireforum.org/forum...hp?pic_id=1692
Old Sep 19, 2004 | 07:55 PM
HDDP's Avatar
Default
Any "Universal" fit Momo shift will fit the Crossfire... The adapters are included in the kit... The only pain is having to to some mods. for the BOOT if you want to change that as well...
It will take you about an hour or so.... Be sure to use the tightest rubber adapter that fits over the shift stem (tapping it down over the shift lever), and the longest allens (set screws)...
Tighten all three set screws like you would tighten the lugs on your car so the shift **** sits vertically and doesn't offset to one side or the other...
I really like the difference between the OEM and MOMO shifter... It conforms more to my hand. I offset the angle to be a bit more ergonomically correct to my wrist position while shifting...
Have fun and would like to see your pictures when you complete...
Goldwing
21
Apr 2, 2025 11:32 PM
Buchacho
Aug 6, 2015 12:48 AM
Buchacho
Jul 22, 2015 12:56 PM
XFIRED-TX
Jul 17, 2015 11:56 AM
XFIRED-TX
Jul 14, 2015 10:48 PM
