Does everyone actually use Mobil1 0W-40?
Thanks,
Don
Don and others...here it is. You will not be disappointed...worked the first time. I will say I did wrap Teflon tape on the 2 treads just to get a tight seal...even before I tried it.
Amazon.com: Air Power America 2000 LiquiVac Oil Changing System for Large Engine: Automotive
I find it hard to believe that 5W-40 (or even 5W-30) would not work just as well and it is definitely more common in this immediate area. Wouldn't 5W-40 or 5W-30 work in a XF? Also, why Mobil1? There are many other brands out there that one would think would be just as good.
Please comment.
Don
Please comment.
Don
Every oil approved is right here:
MB 229.3 - Multigrade engine oils (Specification 229.3) - Mercedes-Benz Specifications for Operating Fluids
Many guys run Royal Purple, I think some here have more than 50,000 miles on their car with no issues using it. We are long past the warranty period, so that is one reason that you can wander from the recommendations.
Yep. I'm at the stage of my life where ....If I'm going to lay on my back and reach upward.....it will only be for one thing. And isn't going to be for changing the oil.
THe current recommendation is Mobile 1 5W40. In the heat of the south, I run 5W40 these days in the winter and 5W50 in the summer. (Well, I DID, when my car was a daily driver. Not sure what I'll do now, the new one is garaged most of the time.)
Here's a link to another reference I posted some time back on motor oils that meet various M-B specs:
https://www.crossfireforum.org/forum/465262-post6.html
As you can see, there are quite a few motor oils that fully meet the M-B specs for these engines.
Later,
Later,
I have 2:
I have the Mityvac 7201 Fluid Evacuator Plus....
The Valvoline SynPower 5W-40 falls under the 229.5 spec for the XFs. All is good....
Thank you sir!
FYI - most Chrysler/Merc dealers in the south use Pennzoil 5W-40 as the OEM replacement for their dealer oil changes!
Regardless of which oil you decide on, here's how it's done :
Blonde Adding Oil To Car Engine
( anyone speak German and can translate ? )
Per my last mechanic MOBIL 1 is not that good, it holds a lot of contaminants. I am using a new Penzoil made from natural gas right now. I'll get the name of the oil he said was best, either Havoline or Valvoline.
As far as the contaminants … I don't believe it for an instant. I have oil reports on my used oil. No signs of anything abnormal or unusual. No contaminants.
I've read really good reports on the Pennzoil 5W-40 Ultra.
Les
Please comment.
Don
Please comment.
Don
