Rattling rear hatch???
Old Apr 15, 2005 | 04:08 PM
jason60050's Avatar
Default Rattling rear hatch???
I notice whenever I go over some crack in the road or any bump the rear hatch rattles and makes noise. I find this very annoying and is there anyway to get rid of it?
Old Apr 15, 2005 | 04:52 PM
cgates's Avatar
Default Re: Rattling rear hatch????
Go to your dealer and tell them your rear hatch rattles, they will replace the latch under warranty.
This is a known issue and a TSB was issued on it.
Old Apr 15, 2005 | 05:26 PM
Wayne1992's Avatar
It might not be the latch. Try adjusting the rubber bumpers located on each side of the hatch. I loosened the screws and moved the rubber bumpers all the way out. That is what fixed the rattle in mine. After that I believe it is the most solid car I have ever owned.
Old Apr 15, 2005 | 06:12 PM
cgates's Avatar
Adjusting the bumpers does take up the slack, and can stop the rattle. That's a work around for the real issue of the latch not holding tight enough.
Either fix will work though.
Old Apr 16, 2005 | 02:55 AM
crossfireS2's Avatar
Just picked up my xfire yesterday and noticed this as well, good info.
Old Apr 17, 2005 | 11:16 AM
Wayne1992's Avatar
These cars are pretty cool but there can be some issues to take care of. I had the hatch rattle, a small crack in the left door speaker grill that somebody kicked while looking at the car (the grill couldn't be put in a worst place) and something loose in the shifter mechanism causing sound to radiate up from the console around 2k rpm which I still haven't gotten fixed yet. Most of the problems that are reported here seem to of a minor nature.
Do you now own two XF's or did you just pick up the 2004?
Old Apr 22, 2005 | 12:09 PM
davenhb's Avatar
I had a loose screw driver rolling around in the cargo area that made a similar noise.
Old Apr 22, 2005 | 12:44 PM
Crossfire-tech's Avatar
I have had one in that the right rear shock was busted due to tie down on the transport truck.
it was not leaking but the only way i could fine it was by removing the rear cover and riding in the trunk now I'm 6' and at that time I was 249 lb's I've lost 22 lb's since then but the shock was just knocking like it had no oil in it and rattled the whole back there is also some issues with the deck lid trim check your dealer or call me and I will look it up in the dealer connect web sight 9:00 to 5:00 405 919-6731.
Old Apr 22, 2005 | 09:11 PM
Wayne1992's Avatar
Hay Crossfire-tech any idea what might be causing noise to come up from the shifter. It also clicks when I shift from one gear to another. There is considerable vibration in the clutch pedal but I test-drove another one and it did the same but didn't make the noise. The noise just happens when I shift and accelerate below 2K rpm. I'm sure it's a minor problem and hasn't gotten any worst.
Old May 27, 2005 | 01:52 PM
Sean's Avatar
Just collected my 05 and sure enough, the rear hatch groans and creaks over bumps.
The latch is okay but the rubber stoppers are a crinkle-cut pattern and I can actually see the crinkle-cut embedded into the duco where they come into contact with the gutter. I figured the little rubber feet flex as the hatch flexes so for a work-around fix I put some loop adhesive Velcro where the stoppers come into contact with the gutters. Cured the issue.
BUT, I still have another very annoying body flex squeak emanating from somewhere in the vicinity of the rear quarter glass, way deep inside the trim, or maybe in the roof lining in the same area ??
The dealer had his tech working on the issue for 4 hours, pulled all the trim and lining out, centre punched body spot welds per TSB, stuffed foam and silicon spray into crevices but all to no avail! They’ll have another crack at it but with the Chrysler field Tech next week. Not impressed for brand new spanker. Will keep you posted.
Cheers
Sean.
Old May 27, 2005 | 05:10 PM
Gene12's Avatar
Have them check the rear latch (a known issue).
Old May 27, 2005 | 05:33 PM
chxf's Avatar
I brought my car to the dealer in order to fix the rattling (warranty). He said after it had to do with the casing. So he did something to it (I saw the fingerprints ;-) but I'm still not satisfied. Gonna see him soon again.
Does anybody exactly know what the TSB says? Is it really about the casing?
Thanks
Old May 27, 2005 | 05:54 PM
cgates's Avatar
Thanks.
See this posting in the TSB section:
https://www.crossfireforum.org/forum...ead.php?t=5135
Mine rattled, I had the latch replaced, no more rattle.
Old May 27, 2005 | 06:25 PM
chxf's Avatar
Thank you very much. So I'm gonna see him definitely next week.
Old Aug 24, 2005 | 11:57 AM
Talking Re: Rattling rear hatch????
Glad to be of help.
Old Aug 24, 2005 | 12:02 PM
SUBJECT:
Rattle Sound From Liftgate Area
OVERVIEW:
This bulletin involves replacing the liftgate latch and/or adjusting the liftgate bumpers.
MODELS:
2004 (ZH) Crossfire
NOTE: This bulletin applies to vehicles built on or before November 27, 2003 (MDH
1127XX).
SYMPTOM/CONDITION:
The vehicle operator may describe a rattle like sound coming from the liftgate area.
DIAGNOSIS:
If the vehicle operator describes the Symptom/Condition, perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
1 05142597AA Latch, Decklid
**1 NPN Powder, Tracing (Castle P/N C1619 or
equivalent talcum/tracing powder)**
REPAIR PROCEDURE:
1. Inspect the liftgate latch assembly. Determine if the vehicle has the updated plastic
coated catch or the old painted catch (Fig. 1).
a. If the vehicle is equipped with the old painted catch, proceed to Step #2.
b. If the vehicle is equipped with the updated plastic coated catch, proceed to Step #3
NUMBER: 23-019-04 REV. A
GROUP: Body
DATE: July 28, 2004
Fig. 1 NEW LATCH ASSEMBLY
1 - BLACK PLASTIC COATED CATCH
2 - LATCH ASSEMBLY
2. Replace the liftgate latch using p/n 05142597AA. Refer to the service information
available on TechCONNECT, Refer to 23 - Body/Decklid/Hatch/Liftgate/Tailgate/Latch
- Removal.
3. Cut a strip of paper to 25.4 mm X 279.4 mm (1 in. x 11 in.). This will be used for a
gauge in the next step.
4. Check for bumper to drain channel contact by placing the strip of paper in the drain
channel as shown (Fig. 2).
23-019-04 REV. A -2-
Fig. 2 PLACING STRIP OF PAPER IN THE DRAIN CHANNEL
1 - LEFT REAR QUARTER PANEL
2 - PAPER STRIP IN DRAIN CHANNEL
5. Close the liftgate.
6. Try to pull the strip of paper out from between the liftgate bumper and the drain
channel.
7. If the strip of paper pulls out easily, the liftgate bumper must be adjusted. Proceed to
Step #8. If the strip of paper does not pull out easily, proceed to Step #9.
8. Open the liftgate. Loosen the T30 torx screw and lower the bumper 1 mm (0.04 in.).
Tighten the T30 torx screw (Fig. 3). Proceed to Step #9 to check the bumper contact.
9. **The liftgate bumper must make full contact with the drain channel. Check for full
contact using spray on tracing (talcum) powder (Castle p/n C1619 or equivalent
talcum/tracing powder). Apply a small amount of talcum/tracing powder in the drain
channel in the area that the bumper makes contact.
10. Close the liftgate.
11. Open the liftgate and check the foot of the bumper to be sure that the talcum/tracing
powder covers the entire surface of the rubber. If it does, proceed to Step #13. If it
does not, adjust the bumper so that it will make full contact with the drain channel.
12. Clean the talcum/tracing powder off of the bumper and drain channel. Proceed to Step
#9.
13. When the bumper adjustment is complete, tighten the Torx screw to 10 Nm (88 in.
lbs.).
14. Clean the talcum/tracing powder off of the bumper and the drain channel.
15. Close the liftgate.
CAUTION: Be careful not to change the liftgate alignment. Refer to the service
information available on TechCONNECT, Refer to 23 - Body/Body
Structure/Gap And Flush - Specifications.
-3- 23-019-04 REV. A
16. If the liftgate alignment is OK, repeat Step #4 through Step #15 on the other side of the
vehicle. When both sides are properly adjusted, no further action is necessary. Return
the vehicle to the customer.**
Fig. 3 LIFTGATE BUMPER
1 - T30 TORX SCREW
Old Aug 24, 2005 | 05:59 PM
chxf's Avatar
Yep ... TSB replacement done! Quiet, not a single sound. Highly recommendable!
Thanks again.
Greets
Old Aug 24, 2005 | 06:50 PM
You get into Oklahoma City come by and get a cup of joe like to get to know a few of you on the board 208 s. I-240
Old Feb 28, 2008 | 09:32 AM
huudoo's Avatar
Old Feb 28, 2008 | 08:22 PM
cgocifer's Avatar
The TSB says for cars built on or before 2003. Mine was after, so the dealer said they would just adjust the bumpers. I said forget it and did it my self. That worked for about 10 miles, then did it again, this time using some medium locktite. Still not permanent. I ended up using some double sided foam tape, but that stopped working after about a week. I'm at a loss! It drives me crazy when I hear that thing rattle!! I'm going to try the loop pad from a Velcro strip next.
